Prelude problem... limp mode?
Old Apr 19, 2010 | 05:41 PM
Elcabritofresco's Avatar
Default Prelude problem... limp mode?
Ok here's the situation. I bought a 92 prelude Si 4ws over the winter as a dirt track car. It runs great for about 5 laps (roughly 2 miles) before it starts to break up... bad. It sounds like its running out of gas or something, or like a very bad skip. I realized this weekend that if I slow the car down when this happens (I put it in neutral and held the brakes for a second), it runs good again for another lap or 2.
It runs poorly whether it is in gear or in neutral. It is in 2nd gear, probably between 5500 and 6000 rpms. Also, I don't think my tach works until it starts running badly. This I'm not 100% positive of, but I know it doesn't normally work but it was when I pulled off the track.
The car has a new ECU, coil, and the previous owner put a new distributor on it. Any ideas whats going on here?
Also, I found a white/yellow wire that has been cut off underneath the dustributor that seems to trace back to the ECU. it is wire D1 (battery)
So, my questions are:
1) What do you think my car is doing, and how can I fix it?
2)What is that wire for? Where is it supposed to go?
3)Any ideas why my tach doesn't work?
Thank you so much to anyone who can lead me in the right direction with this.
Old Apr 19, 2010 | 06:50 PM
duanes's Avatar
Default Re: Prelude problem... limp mode?
Search the internet - there is a complete shop manual (FREE) for 92-94 Prelude for download. It has complete wiring schematics and full troubleshooting diagrams. The one I found has a black cover page.
Old Apr 19, 2010 | 08:32 PM
Enzo15's Avatar
Im gonna go with the pump maybe not supplying enough fuel for a long enough time.
Old Apr 19, 2010 | 09:06 PM
BigBlock22's Avatar
is the distributor for an obd2 engine? my civic w/h22 uses the original obd2 engine harness so i wouldnt be exactly sure where the white/yellow wire on the obd1 prelude goes but on my car it goes to the alternator. by the way, are there any check engine light indications going on while the car is running like crap?
Old Apr 19, 2010 | 09:15 PM
BigBlock22's Avatar
another thing, limp mode would not let you go past 3,000 rpm depending on which code it is but usually will not allow vtec to work. that is if you have a CEL
mahlberg22
Aug 23, 2015 05:39 PM
socalfun
Jul 14, 2013 04:43 PM
VtecPush
Jan 27, 2006 10:25 PM
tgreaves
Oct 2, 2003 10:18 AM
ryans
Dec 16, 2001 07:11 AM
