Running a D16y7 but with all my obd0 stuff?
My motor spun a bearing today on the freeway and now I'm looking for a motor. My buddy has a y7 with 140k on it and I know that it's been taking VERY well takin care off. He's selling the y7 with an Si trans, ecu, harness, radiator, hoses and all the sensors. Now I don't wanna convert it all to OBD1 hence more money, but can I just use my obd0 dizzy and PG7 ecu?
All insight is appreciated. Money is REALLY tight since I'm only making about 600 a month. I was planning on selling the wiring harness and the trans to make up some money as well if I do get it so I can buy a couple things if I do need to convert to OBD1.
My car is multi-port swapped as well.
i read on here not too long ago that if you runn diff obd's you will get something going on with ure car!
i think u need to run all the same obd's like ure going to have to run all the same obd1 or ob2 ect
correct me if im wrong
zeusdavis
14
Mar 28, 2011 08:05 AM
