The race to I.A. '10 **white ej8**
Old Apr 18, 2010 | 10:38 PM
95lscivic's Avatar
Default The race to I.A. '10 **white ej8**
What's up guys and gals? My car has been pretty stagnant for the last year. That doesn't mean I haven't been buying parts though. My 1998 civic coupe as it sits has a stock b16 and some visual enhancements. In the next month or so I'm going to tear the motor out, add some go fast goodies, respray the engine bay, add some stopping power, a few interior bits, and some new shoes.
Before the madness begins this is what it looks like:
I already of course have some parts on the car such as a 96 spec ITR hub conversion, K Sport coilovers, EK4 bumper conversion, JDM thin side moldings, B16a swap, Exedy clutch, ACT 11 lbs. flywheel, and a few other small things here and there.
Here's what I got right now going onto the car:
2005 Maxima bi-xenon projectors
9012 H.I.D conversion kit
New OEM headlights for retrofit
Circuit Hero shift **** and extender
JDM ek4 gauge cluster
BNIB 16x8 final edition +35 Regamasters
5mm spacers
Black vision open ended lug nuts
98 spec ITR calipers
Prelude VTEC cross drilled and slotted rotors
Axxis ceramic Pads
Hy-tech replica header w/ v-band flange
Custom t304 tig welded v-band exhaust through a vibrant flat black muffler
New front inner fender liners
Jackson Racing Supercharger with a 4.2 inch pulley completely torn apart, powder coated, and rebuilt with all new parts
LS crank pulley (should net 8.6 lbs of boost)
Precision Industries 440cc injectors
Walbro 255lph fuel pump
Benen Industries composite fuel rail
Adjustable fuel pressure regulator
BNIB ITR exhaust cam
GSR intake cam
NGK BKR7E plugs
Fidanza adjustable cam gears
B16 intake dual valve springs and retainers for the exhaust side of my head
Hondata s100 with boost
New OEM p72 water pump
New OEM timing belt
New OEM timing belt tensioner
GSR aftermarket intake
Gates 170 degree thermostat
Aluminum radiator
Comptech ICEBOX
I don't have pics for it all right now but I'll add some more as I take the pics and the progress builds.
Build night #1
Pullng the motor and Starting to tuck the harness
Old Apr 18, 2010 | 11:36 PM
Sic_DA_Nine's Avatar
Default Re: The race to I.A. '10 **white ej8**
nioce
Old Apr 19, 2010 | 01:12 AM
steveDC2's Avatar
sweet
Old Apr 19, 2010 | 03:31 AM
Mugen_Stumpo's Avatar
i love the before... i could imagine how good the after will be
Old Apr 19, 2010 | 04:10 AM
516EK9's Avatar
cant wait to see how this turns out. good luck
Old Apr 19, 2010 | 07:43 AM
95lscivic's Avatar
Thanks guys! should have updates tonight.
Old Apr 20, 2010 | 07:48 PM
JdmOdz's Avatar
this should be good.. keep me posted!
Old Apr 20, 2010 | 09:49 PM
Smokinsax's Avatar
The Boot
in for the progress...this should be a pretty good build.
Old Apr 21, 2010 | 02:31 AM
ken9's Avatar
O.k...
Old Apr 21, 2010 | 03:49 AM
OhMy-EK9's Avatar
wow nice build big up for IA10 build im on the same boat
Old Apr 21, 2010 | 03:54 AM
markspan6243's Avatar
Flattery Will Get You Everywhere
lookin forward to keep watch on this thread
Old Apr 21, 2010 | 01:25 PM
MLRtime's Avatar
in for updates.
Old Apr 21, 2010 | 01:48 PM
switchjv's Avatar
wutz up??? wheres the updates?
Old Apr 21, 2010 | 07:20 PM
marc-111's Avatar
goodluck on the build!
WHITE EJ8 FTW all day!!!!!
Old Apr 21, 2010 | 11:13 PM
95lscivic's Avatar
Finally got some work done tonight! Motor is out and I started to get the right side projector retrofit ready. Should be done tomorrow. Here's some better pics too, not from the iphone!
Motor, about to be out.
Motor is out, look on the passenger side shock tower. There is some rust just below the seam sealer one of the big reasons for the tear down.
Here's a pic of the 98 spec ITR calipers with 93 prelude vtec slotted and drilled rotors on my 96 spec ITR hubs. Had this set up on for about two weeks before the tear down so I am still including this in part of the build.
And lastly, like I had stated before I started on the retrofit. Here's the progress.
05 maxima bi-xenon's
Finally starting to come together after about 2 hours of cutting and measuring.
Then there was this big bastard who thought my ecu would be a good resting spot :lol:
Old Apr 22, 2010 | 03:11 AM
rhdej6's Avatar
clean coupe... n wtf! trippy *** spider .**** looks deadly..
Old Apr 22, 2010 | 01:08 PM
95lscivic's Avatar
Also went ahead and bought this personal fitti e5 350mm wheel last night! Waiting on just a couple parts now. My keepitcleanwiring.com stretch fit looming for my harness and my benen industries carbon composite fuel rail.
Old Apr 22, 2010 | 02:19 PM
87CRX's Avatar
i think i need a new pair of boxers after looking at that spider.
clean ride though! gl!
Old Apr 22, 2010 | 05:13 PM
jnemci's Avatar
i think would have to sell the car. just knowing there might be another one.... f*** spiders. good luck on the build
Old Apr 22, 2010 | 11:52 PM
95lscivic's Avatar
Small update... What a process retrofitting headlights is... Wasn't really sure what I was getting into when I started and after 4 hours I still am only about 80% done, with one headlight. Anyways here's the only pic I took tonight. I must say though, not to toot my own horn, it's looking pretty sick!
Old Apr 23, 2010 | 07:02 AM
Smokinsax's Avatar
The Boot
Did you need to use the 98 spec ITR calipers with prelude rotors on the 96 spec ITR hubs? Why not just use the 96 calipers? Where there modifications needed to make this all work together or was it straight bolt on?
Old Apr 23, 2010 | 07:16 AM
my95dc2's Avatar
DAMMMN I dont **** with spiders.. After watching all the youtube videos or nasty *** spider bite pluss globs, I dunno. Car is moving right along, Im thinking of getting the 4x114.3 ITR setup when I get around to my rear brake upgrade
Old Apr 23, 2010 | 08:48 AM
whiter14's Avatar
kick a$$ build man, see ya at IA10'!!!!!!
Old Apr 23, 2010 | 11:38 AM
95lscivic's Avatar
Smokinsax yes I used the 98 spec ITR calipers with prelude vtec rotors on my 96 spec ITR hubs. I did this because the 98 spec ITR calipers allow for almost an inch larger rotor with significantly more clamping force than the 96 spec ITR calipers. I used to run the full 96 spec setup but decided to go this route for better braking performance. It is essentially a direct bolt on yes, but you have to use a 1/8mm shim on the brake bracket for it to bolt together correctly inside the brake caliper. Hope that was of some help to ya! Should have more updates tonight!
Old Apr 23, 2010 | 11:42 AM
Smokinsax's Avatar
The Boot
great info...
So far I have far superior braking with my 96 spec ITR brake conversion on my CRX than with the stock setup. We will see how much farther I will delve into racing...if I ever need to upgrade my brake setup I will def be coming back to this info.
