Clutch Pedal Issue
depending on your setup, you could potentially have a wrong hydraulic component, ie mstr cyl or slv cyl. or if it is a cable clutch a simple adjustment can take care of that
follow the clutch cable down to the transmission, you will find thqat on the cable there is a thumb wheel adjustment, pull up on the cable while loosening the thumbwheel. now with the cable pulled up, tighten the thumbwheel down until it makes contact with its mating surface and add another 2 turns. assuming this is a stock clutch your adjustment should be spot on
Ricextacy
Jan 18, 2012 09:12 AM
InJ3cted
May 24, 2005 02:16 PM
