Help with my mini-me swap...
Old Apr 18, 2010 | 04:57 PM
what the ef's Avatar
Default Help with my mini-me swap...
So im planning on swapping a d16z6 head into my 91 civic sedan. So I know the stock d16a6 engine is obd0 and the z6 is obd1. Along with the head I have a complete z6 wiring harness and a P28 ECU. So I was just wondering if this is all I needed to do the swap because I asked around and some people said that I have everything I need since I have the P28 and other people told me that I cant use just the wiring harness and the P28 to make it work. Any help/tips/advice would be appreciated, thanks.
Old Apr 18, 2010 | 05:52 PM
D16SiHatch's Avatar
Default Re: Help with my mini-me swap...
well you will need an obd0 to obd1 jumper so that you can plug in the p28
http://rywire.com/store/8891-crxcivi...8a857f08494588
and you can't use the z6 harness unfortunately. connect the stock harness to the z6 and then run the appropriate wires for vtec solenoid, vtec pressure switch, and 4 wire o2 sensor.
Old Apr 18, 2010 | 07:20 PM
Ok thanks. So I need to use the wires from the z6 harness and run them straight to the jumper? And is rywire the only place to get the obd0 to obd1 harness? Sorry if my questions seem stupid but this is obviously my first mini-me swap.
Old Apr 18, 2010 | 07:25 PM
D16SiHatch's Avatar
no rywire is not the only place, but i recommend them. you can find jumpers cheaper elsewhere, but the rywire jumper is a great product and easy to use. the subharness is setup with the plugs already on it so all you have to do is run them into the bay and connect them up. plus it comes with the obd0 to obd1 dizzy adapter.
Old Apr 18, 2010 | 09:09 PM
Alright. Yea I was looking at the rywire harness and it looks like it is pretty much plug and play. Thanks for your help.
alexzhere
Jun 4, 2013 01:35 PM
B2KHonda
Jul 12, 2009 01:16 PM
puertoricanboy90
Feb 1, 2009 09:10 PM
antballs420
Jan 4, 2006 10:44 PM
c.dub
Jun 20, 2005 05:04 PM
