cam-gear key way keeps snapping
Old Apr 18, 2010 | 03:47 PM
civic46's Avatar
Default cam-gear key way keeps snapping
ok so i got a problem....i put my aftermarket cam in my crx...all stock except cam,,,and ive sheered the key way off the stock cam gears (2).....what would cause this????
Old Apr 19, 2010 | 05:08 AM
civic46's Avatar
Default Re: cam-gear key way keeps snapping
anyone got any idea;s?
Old Apr 19, 2010 | 07:40 AM
rustanghunter's Avatar
is it a super aggresive cam? get a quality adjustable gear
Old Apr 19, 2010 | 07:51 AM
civic46's Avatar
its a stage 2 bisi cam....its for a race car and rules stat stock grear must be used.
Old Apr 19, 2010 | 08:04 AM
i thought bisi cam gears where recomended?
just looked and bisi cam gears and valve prings recommended, now we know why
Old Apr 19, 2010 | 09:11 AM
jlicrx's Avatar
did you check piston to valve clearance? sounds to me like the pistons are hitting the valves and stopping the camshaft
Old Apr 19, 2010 | 09:15 AM
89LSED's Avatar
I second this! My cuz had the same problem, he popped a key, and the was a very very slight noise to the motor, but it was really hard to figure out what it was. it finaly went away because he had grovved the pistons. im surprised it didnt bend any valves. but everything was all good
Old Apr 19, 2010 | 08:22 PM
HondaManMike's Avatar
check cam cap torque, and make sure you havve a reputable cam gear on there. dont forget to properly degree your cam as well
Old Apr 19, 2010 | 09:23 PM
ASO's Avatar
ASO
your cam could be seizing in the head i had this happen to me on my z6. does the motor run then stop instantly?
blurry454
Nov 18, 2009 11:55 AM
CPR
Jan 20, 2006 09:06 PM
TylerH
Nov 18, 2004 07:12 PM
Gump
Sep 20, 2004 03:09 PM
94GSRNewbie
Jul 26, 2001 11:06 PM
