ECU help please!!!
I bought a Gs-R a few weeks ago. The car is an original gsr but the guy who had it before me had an LS engine in it and he got drunk and sold his engine and tranny for $100! well he had a Gsr swap back into it a few months ago and i was going throught the car the other day and realized that it came with a 99 civic sohc Ecu... not sure what code/model it is but i want to go back to Gsr ecu but i dont know whether my gsr engine is OBD1 or OBD2.. i found a pretty good deal on a OBD1 for $80 obo. Do u guys thnk it will make become a problem what gsr ecu i use.. or can u help me identify what OBD# my gsr engine is?
Thank you in advance for any suggestions!!!
chances are, if theres a 99 civic ecu, your car is a 98 or newer? if so your gonna need an obd2b p72. you can use the obd1 ecu but your going to have to spend the money on an obd1 jumper harness
Need more info. What year the integra is. And what year the head is. Look on the front of the head above the exhaust manifold for the numbers. Or if it is a GSR motor, how many O2 sensors do you have before the cat? OBD1 only has 1 and OBD2 has 2.
me and my friend are gonna replace a cam seal and tap the engine block so ima check those numbers, is that the only place to find those nubmers on the block?
the engine year doesnt matter, whta year is the car? obd1=94-95. obd2a=96-98. obd2b=99-01. find out what year your car is and that will tell you what ecu you need
it doesnt matter what year the engine is, the car determines what obd version your using. if you want to know the year of the engine, look on the cylinder head just above the exhaust manifold, there are 3 stamp's. the one nearest the passenger side of the car is the year the motor was made
im trying to get this fixed soon ahah
Attachment 124050
Attachment 124051
the on with two plugs is obd1 and the with one plug is obd2. that will at least clear up what distributor you have.
Attachment 124051
ill look into it tomorrow, ima replace the cam seals and tap my block and ill get that cleared out at the same time = D
