Buddy club spec 2 exhaust springs
Old Apr 17, 2010 | 10:23 PM
DC2many's Avatar
Default Buddy club spec 2 exhaust springs
the springs are on the far right.
anyone know where to get those springs or know the specifications? how long are they and do you pull them from ear to ear w/ pliers?
buddy club themself is 20$ and takes time and shipping
i've got some springs at a motorcycle shop b4 and i shot that thing across my garage and popped a hole somewhere...
any hardware store didn't have any either.
thanks
Old Apr 17, 2010 | 10:32 PM
BAYsikDC4's Avatar
Default Re: Buddy club spec 2 exhaust springs
have you checked lowes or home depot? i just searched springs and i found some similar to the ones you are looking for.
http://www.lowes.com/pl_Hardware_429...Ntk=i_products
Old Apr 17, 2010 | 11:16 PM
DC2many's Avatar
yea ive checked
home depot
lowes
auto stores
ace hardware
dale hardware
the closest ones i could fine that is closest to the bc springs are the ones from motorcycle shops. other springs are too fat or etc and can't clear the ears and waht not
Old Apr 17, 2010 | 11:26 PM
BAYsikDC4's Avatar
oh i see how are those working out? you can probably use metal wire and twist them together lol
Old Apr 18, 2010 | 12:02 AM
Local's Avatar
Yeaaa those are a bitch. If u don't have em I would us metal wire like mentioned above maybe temporary solution.
I had the exact same springs on my BC GT2 exhaust. The exhaust will still feed into the tube about 4 inches and fit flawless in diameter after a while. I would say u could get away without them as they didn't seem to serve too much of a purpose other than some peace of mind. Keep an eye on it
Old Apr 18, 2010 | 01:02 AM
DC2many's Avatar
lol thats why i need them, i have mad leaks from the slip on points, and one time i decided to move the hangers i touched the mid pipe and it just fell off =\
Old Apr 18, 2010 | 04:01 PM
DC2many's Avatar
bump \
Old Apr 18, 2010 | 04:16 PM
danthemang3's Avatar
i got some from burns stainless not sure if they will be the correct length or not. i bought them for a diff. application
Old Apr 18, 2010 | 10:42 PM
DC2many's Avatar
do you have pics of them? i might go check out some other motorcycle shops again.
how do you pull the springs from ear to ear on the exhaust? those springs have so much tension that if you dont grip enough they shoot off and could possibly kill something lol... from wat i've see i blew a hole thru a few cardboard boxes in my garage and it shot fast...
also pulling them is pretty hard as well due to that
Old Apr 19, 2010 | 12:15 AM
vtaker's Avatar
I'm pretty sure they have some at my local OSH hardware store. They might not be high tension though. Any motorcycle dealer parts dep. should have them too. Otherwise, just spend the $20 and call it a day lol.
If you can't do it with a screwdriver, try a drum brake tool from any tool store specifically the one that looks like a pigtail and pliers:
Old Apr 28, 2010 | 07:40 PM
DC2many's Avatar
is this safe?
the spring has a good deal of stretch to get on there especially on the other ears
Old Apr 29, 2010 | 05:14 PM
DC2many's Avatar
bump
Old Apr 29, 2010 | 09:46 PM
vtaker's Avatar
looks good to me. it's suppose to have a lot of tension to hold the two exhausts together. depending on what they're made out of, they could wear out from heat or rust in a few years but nothing to worry about now. good job getting them on.
Old Apr 30, 2010 | 12:25 PM
welltal89's Avatar
why not weld them where they are? what's the advantage of having springs that hold the exhaust together?
Old Apr 30, 2010 | 11:07 PM
DC2many's Avatar
the point of not welding them is so you can take it apart... instead of having to cut the entire thing when the time comes to change or smog etc
Old May 2, 2010 | 06:38 PM
welltal89's Avatar
oh, nice, good point, well in that case just buy the springs, but if it were me i would just weld them on. you could always just pop off the hangers if you need to put in the stock exhaust back on.
Old May 2, 2010 | 08:35 PM
DC2many's Avatar
not necessarily, pulling off the whole exhaust if its all welded would be pretty hard. how will you get the axle back part off ? its very angled and has U bends
there are 2 sections of the spec 2 that require the springs and 4 springs total
mid pipe to S pipe S pipe to axle
Old May 4, 2010 | 08:56 AM
welltal89's Avatar
thats why you have friends to help you out lol, but in all seriousness, just go with the buddy club springs
hatch_
Oct 11, 2006 08:04 AM
Wazup
Suspension & Brakes
Sep 7, 2005 05:14 PM
Mychael1
Apr 27, 2002 07:48 AM
