is there an easy way to set balance belt?
i know that you have to use a maintenance bolt to set the rear balance shaft, my question is, is it required or is there another way? thanks
Just give it a good spin, due to the offset weight of the balance-shaft it will stop in the right position. If that doesn't work, which 90% of the time it does, you could always do the High School locker method, which is explained in detail here; http://www.wikihow.com/Open-Your-Locker
