Powerlocks intermittently works
No it has to do with parts failing haha. Not the age of the car necessarily.
Is it just one of them? It could be the lock actuator is dying in that door (~120 for the part) it could be the master control switch. I know someone had luck with Electrical Contact Cleaner and spraying it into the switches (just had crud on the contacts) I would recommend taking apart the door though before doing that.
The actual switch panel on the door, if you pop out that section (remove from door panel) and strip it down you can get to the contacts for the switches.
The ghetto way would be to spray it in the holes around the switches while the door is still together. You just run the risk of possibly staining the interior panels.
I thought I was the only one with that problem. well actually only my driver door works now. I have to manually open the rest of the doors for my family. I hope cleaning it will make it work again
bdoberst
Jan 7, 2015 11:55 AM
XIV
25
Aug 7, 2014 06:51 PM
rak007
Jan 11, 2012 05:34 PM
