B&R Fittings catchcan kit, valve cover, etc
I am making myself another oil catch can so I have no more need for these. Up for sale is a B&R Fittings catch can kit that vents the back of the block. Like this but for the back of the block. I will post pics of it tonight. Comes with all the lines ready to install. $250 obo
http://www.hondamarketplace.com/show....php?t=2020429
I also made this catch can to give me a little more capacity. It is a bit larger than the B&R can but still fits between the battery and stock fuel filter. It is also baffled and will come with filter. I have put the custom one by the battery and the B&R can in front of the shock tower as seen here. The lines off the valve cover will be included as well. $160 obo. or $260 with valve cover
B-series vented valve cover with -10an bungs welded on. Oil cap not included. Will need to be painted. $125 obo
I have other things I need to get rid of that I will post later as well.
Hmm apparently I can post in the forums, but sending a PM is blocked at work for me.. Not sure if the message sent. Anyway, I'm interested in the catch can that mounts beside the battery. Would you be willing to ship to Canada? I can pay via Paypal. Will you include the lines/fittings/filter for this? I need basically the identical setup as seen in your picture, with the lines running to the two big fittings on the back of the block to vent crank case pressure.
Thanks,
Scott.
Thanks,
Scott.
Acoutic- I did receive your pm and I replied!
newsol- Do you want the custom one or the B&R fittings can that is hooked up to the lines off the valve cover?
champLSinteg
Northern California (Sales)
Apr 20, 2010 06:26 AM
Nisif
46
Apr 18, 2008 03:49 AM
migs
22
Mar 26, 2008 05:23 PM
