Torque mount question B series swap
Old Apr 16, 2010 | 11:14 AM
Budget Racer's Avatar
Default Torque mount question B series swap
Hello All,
I'm having trouble locating torque braketts for my B series swap. I was wondering if I could use the After Market Torque Dampener in it's place. You know the one that mounts on the head somewhere?
See pic
Old Apr 16, 2010 | 12:16 PM
98civdx's Avatar
Master Detailer
Default Re: Torque mount question B series swap
I dont know how you would mount it to the block, but the torque mounts are on the front of the engine and tranny. You may not even have them if it's swapped.
Old Apr 16, 2010 | 12:43 PM
Did you read my post? Yeah I know where they go. I stated already I dont have them.
I have a swap that I'm waiting to do its not in my car yet. The Torque Dampener does the same thing as the torque mounts I believe. They stop the back and forth torqing. Just not sure if its enough by itself.
Old Apr 16, 2010 | 02:38 PM
98civdx's Avatar
Master Detailer
You never said you didnt have them, you said your haveing trouble locating the brackets, and yes i read your post
Old Apr 20, 2010 | 08:40 AM
OK well I meant having trouble locating ones to buy!! Oh Well
Old Apr 20, 2010 | 08:42 AM
This is what I want to know
I was wondering if I could use the After Market Torque Dampener in it's place. ??
^^ (in place of torque mounts)
Old Apr 20, 2010 | 11:19 AM
itsnotfast's Avatar
Just looking at the bracket, I don't think it will work. If mounted in place of the factory torque mounts, that one would just twist.
Old Apr 20, 2010 | 01:08 PM
kaduku_'s Avatar
no you dont mount that in place of the factory torque mounts. they go around where the cruise control would be (that area). try it and see if it helps at all (less wheel hop) because i was looking into these myself for the longest time because i think the engine bay looks nicer without the torque mounts. i gone through energy suspension inserts on all the bottom mounts, hasport motor mounts without the torque mounts and lastly i want to try the torque dampener so lemme know wassup when you do.
Old Apr 20, 2010 | 01:44 PM
98civdx's Avatar
Master Detailer
Your better off getting mounts, hasport,avid inavative.
Old Apr 21, 2010 | 01:13 PM
I see I need to be really really specific on this post lol.
I don't want to install the unit in the same place as the torque mounts just substitute it as function only. I know they don't bolt up where the torque mounts are, but bolt it where its supposed to be. They are made to do esentially the same thing but diff locations.
98civdx those mounts would be great just dont wanna spend that kinda money yet.
Old Apr 22, 2010 | 09:19 AM
itsnotfast's Avatar
I have never seen these dampners before so I wasn't sure where you were talking about putting it or weather your pictured part was even for a Honda application. Even if you mount it on the head in the cruise control area as stated above, I cant see how that will even help; Provided you are talking about putting it where the cruise unit came out. The only structurally strong enough place to mount it would be somewhere on the frame rail. You are trying to keep your motor from "rolling" forward and backward on the right and left side mounts, that pictured dampner (if I am reading this correctly) would dampen the motor from moving side to side and unless you're rear wheel drive would do you no good. Correct me if i'm wrong.
Old Apr 22, 2010 | 10:12 AM
SLURS's Avatar
good question because i dont have those mounts
Old Apr 22, 2010 | 10:28 AM
98civdx's Avatar
Master Detailer
^ There is alot of people that do not have them, and theres even more people that feel they are not needed, with afermarket mounts.
Old Apr 22, 2010 | 12:51 PM
NOOdS's Avatar
i have one on my b18c1 swap. im using ingalls torque damper.
i would recommend having torque mounts too if you dont want your engine to move at all.
ive tried a few combinations.
innovative mounts = engine moves (twists) while revving, little vibrating.
innovative mounts + oem torque mounts = little engine movements while revving, little vibrating.
innovative mounts + avid torque mounts = no movements, but lots of vibrating.
innovative mounts + oem torque mounts + ingalls torque damper = no movement at all while revving, little vibrating. (best combo for me)
Old Apr 26, 2010 | 10:37 AM
Thanks NOOdS.
What I was actually wanting to do was use the torque dampner untill I can locate OEM torque braketts and mounts. I hear people running without them but also hear the tranny could get messed up from twisting.
JPerkMr954
Mar 9, 2011 02:50 PM
Dekorum
May 23, 2010 07:08 PM
vsmftw98
Feb 25, 2010 03:07 PM
Civic*B16A3*Eg
May 4, 2007 04:38 PM
ahemming06
Feb 22, 2007 09:32 AM
