Dash light tail light headlight problem?
Old Apr 15, 2010 | 07:57 PM
cor4ey's Avatar
Default Dash light tail light headlight problem?
the tail lights do not work. i've checked both the bulbs and the fuse. When i turn the parking lights on they do not come on but when i turn the headlights on (second click) the headlights come on but the tail lights and corner lights still do not? any suggestions? the fuse is good and so are all the bulbs.
Old Apr 15, 2010 | 09:27 PM
Creator's Avatar
Default Re: Dash light tail light headlight problem?
If your dash and your tail lights are not working it is most likely the fuse. (just cause you can't tell doesn't mean it's not blown switch it with another to be sure) Only other thing that could be the culprit is the ICU (integrated control unit) which is locate on the other side of the fuse box under the dash.
Old Apr 16, 2010 | 03:53 AM
netfreak's Avatar
Mine shorted while I was on a highway in the middle of nowhere without my electrical tools. The short caused damage to the fuse holder so when I put a new fuse in, it still didn't fix the problem. I ended up jamming a paperclip in there just so I could get my car home without being chased by police... Check for charring on the fuse holder.
byc_cb7
Sep 28, 2009 02:45 PM
95silverteg
Sep 30, 2008 04:48 AM
jacksonww
May 28, 2008 08:29 AM
gsrcivic619
Mar 23, 2006 10:53 AM
