ATTN Algebra/Excel lovers: need an AFR slope equation
Old Apr 15, 2010 | 07:04 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default ATTN Algebra/Excel lovers: need an AFR slope equation
Hi!
Objective: Dissecting Autotune to use universally.
* Convert an AFR difference (i.e. -1.5, if target=13.5 and O2=12) into a percentage.
* Apply the percentage to an existing fuel cell value.
Here's my current formula (I know, it's wrong)...
y - (-0.1x)(-1y) (Based on 10 increments from 10-20 AFR)
x = AFR difference
y = fuel value
i.e. 300-(-10%)(-300) = 330
x = -1
y = 300
Any suggestions?
Old Apr 15, 2010 | 09:24 PM
MrDomino's Avatar
Default Re: ATTN Algebra/Excel lovers: need an AFR slope equation
Originally Posted by VegasInvasion
Hi!
x = AFR difference
y = fuel value
x = -1
y = 300
Any suggestions?
Wait, what? Explain what you're trying to do again.
Old Apr 16, 2010 | 01:12 AM
GT35R_EF's Avatar
Make mine whatever you want
This.
Hmmmm, I know what you're looking for kinda. Explain your thought process with your original equation a little bit, and why you came up with that.
Old Apr 16, 2010 | 04:32 AM
93turbo16's Avatar
I am not sure why you would need a "slope" equation. It is just a percent difference.
For example.
target is 13.0 and actual is 15.0 and fuel cell value is 400.
15.0 / 13.0 = 1.15 (+ 15%)
400 * 1.15 = 460
Target is 13.0 and actual is 12.0 fuel cell value is 400.
12.0 / 13.0 = .92 (- 8%)
400 * .92 = 369
So the equation is
(Actual / Target) * current fuel value = New Fuel value
I am pretty sure that is right, but who knows it is too early for me.
Old Apr 16, 2010 | 04:42 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
this is correct...actual/target is your fuel value multiplier. works for afr and lambda...
Old Apr 18, 2010 | 10:47 PM
MrDomino's Avatar
And equivalence ratio which is just 1/Lambda
Seriously I hate engine research. Who came up with equivalence ratio?
Old Apr 26, 2010 | 03:02 PM
I'm Huge In Japan
Great responses, thanks! Okay I'll explain in case you have any additional input.
This is an excel worksheet, part of an educational project.
Table 1 = Target AFR's.
Table 2 = Imported AFR's.
Table 3 = Existing fuel values.
Table 4 = Export fuel values.
For the areas I have no AFR data for ("=0"), how can I condition those cells to avoid a "0" output?
Old Apr 27, 2010 | 10:02 AM
ddd4114's Avatar
IF( [Measured AFR] > 0, [Current Fuel Value] * [Measured AFR] / [Target AFR], [Current Fuel Value])
This will keep the existing fuel value if you don't have a measured AFR for that cell.
Old May 5, 2010 | 11:43 AM
I'm Huge In Japan
that is bad ***. thanks a million Mr. Norris.
PS, Texas Ranger sucked, but your martial arts competitions were magical.
NACvicSi
Oct 29, 2013 04:23 PM
C_H_A_D
Welding / Fabrication
Apr 6, 2007 07:23 PM
k-series
Oct 5, 2006 11:00 AM
mrcrimane
Aug 9, 2003 11:43 AM
THE SOUND OF VTEC
Apr 28, 2002 09:34 AM
