Intake Manifold vs Throttle Body
Old Apr 15, 2010 | 06:22 PM
snowskater34's Avatar
Default Intake Manifold vs Throttle Body
Simple Question.. which one by itself would yield more power to skunk2 tuner series camshafts. i can only get one so i was just woundering which one or none and save the money. It is going to get tuned afterwards also.
Old Apr 15, 2010 | 06:25 PM
D16SiHatch's Avatar
Default Re: Intake Manifold vs Throttle Body
definitely intake manifold. now without other supporting mods, on a mostly stock engine, neither one of these things will make much a difference.
Old Apr 15, 2010 | 06:26 PM
Deetz's Avatar
Crazy Honda Guy
That's kind of a broad question depending on what setup you are running.
For the most part, they run hand in hand. If you run a larger throttle body, you must modify the intake manifold by port matching it, other wise no power increase will be realized.
Old Apr 16, 2010 | 07:44 PM
setup is..Cold air,stage one cams,cam gears,fuel rail and pressure regulator,hondata s100,Msd blaster SS,UR pulleys,4 to 1 header with hi-flow cat and cat back exhaust. So basically a stock motor right..and my stock intake will flow enough are for what i have? I also was was thinking about just getting the TB spacer.
Steeve_Civic
Jan 19, 2014 04:28 AM
95eggsr66
K Series
Sep 8, 2013 12:45 PM
stutler_jdm
May 14, 2011 09:05 PM
ReggieGrip
Nov 3, 2005 01:08 AM
