7mm spacers with stock wheel studs
Old Apr 15, 2010 | 04:42 PM
misha's Avatar
Default 7mm spacers with stock wheel studs
4x100 91 4dr civic
Is it safe?
thanks
Old Apr 15, 2010 | 07:03 PM
sake138's Avatar
Default Re: 7mm spacers with stock wheel studs
I wouldn't go bigger. when you thread the lug on make sure it does like 3 full rotation and then you should be fine. any bigger i would say get some extended studs
Old Apr 20, 2010 | 05:21 AM
nsxtasy's Avatar
H-T Order of Merit
WRONG, WRONG, WRONG!
Depending on who you talk to, you need somewhere between six and seven full rotations on your lug nuts to be safe. If you only have three rotations, your wheels have a very good chance of coming loose. Don't do it!
Old Apr 20, 2010 | 07:57 AM
misha's Avatar
so safest way is to get longer studs?
Old Apr 20, 2010 | 08:12 AM
nsxtasy's Avatar
H-T Order of Merit
Yes, extended studs with open-ended lug nuts. But you can use the stock wheel studs IF you have at least 6-7 full turns on the lug nuts. (Three is not enough.)
Old Apr 20, 2010 | 02:22 PM
misha's Avatar
i didnt think 3 was enough, just doesnt seem right anywway. May be he got mixed up with a rule of thumb for 3 threads on a sheet metal screw
Old Apr 22, 2010 | 02:54 PM
trifenix's Avatar
u need at least 6-7 rotations, unless u want to check your nuts every week...but i wouldn't bet your life on remembering.
Old Apr 22, 2010 | 03:08 PM
TomsEF's Avatar
Inactive account now known as MyspaceTom
i have 7 mils stock studs. all i have to say is dont do it! havent had a prob but not a good idea.
Old Apr 25, 2010 | 10:13 AM
misha's Avatar
sorry you have what? and why not?
Old Apr 25, 2010 | 11:30 AM
WhiteSlips's Avatar
I have 5mm on mine with aluminum lugs and have driven on them that way for over a year. 5mm makes me a little nervous, so I'm sure 7 is too much. I just make sure my lugs are tight every couple weeks.
Old Apr 25, 2010 | 12:36 PM
r.wright's Avatar
translation: dont do it on stock studs.
case closed and thread..thanks for sharing.
paulzy
Nov 8, 2008 09:59 AM
Toy Civic
Jun 6, 2008 01:06 PM
ScottEK
Sep 7, 2004 11:42 AM
mingbling
Jul 27, 2004 09:05 PM
vietboixstunnah
Aug 28, 2002 08:23 AM
