Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
Ground Control coilovers for Gen 1 insight
Old Apr 15, 2010 | 03:04 PM
crx(gator)'s Avatar
Default Ground Control coilovers for Gen 1 insight
I am in talks with GC and they would need someone in the Sacramento, CA area to go to the shop to be the guinea pig. I would do it, but I'm in NY. Anyone here that would be up to this?
Old Apr 20, 2010 | 06:14 AM
crx(gator)'s Avatar
Default Re: Ground Control coilovers for Gen 1 insight
wow, no one?
Old Apr 20, 2010 | 09:37 AM
rsxpimp's Avatar
damn if i was closer i would take my insight over there. i'd be down for a set if they make them. i need something stiffer for drag racing.
Old Apr 23, 2010 | 06:38 AM
theblackbullet's Avatar
regular civic coilovers aren't compatible?
Old Apr 23, 2010 | 08:03 AM
crx(gator)'s Avatar
no
Old Apr 23, 2010 | 09:49 AM
mustclime's Avatar
Just work out what you need on your own, whats so f-ing hard? People are so dam lazy these days.....make a list on what you need so you can order all the parts you need......something like this....
strut body dia......you need a ruler for this....
total suspension travel......ruler, mesure the exposed shock shaft f&r
corner weights.........corner weight scale is the best, many shops have them but if you shop around for a fat peoples scale, they can work also.
motion ratios.....jack stands, a ruler and a jack to move the suspension one inch.......easy
upper spring purches.....this might be a little internet work, look up the part numbers of your upper stock strut tops and strut top bearings....not compair them to other hondas part #'s that GC makes kits for.....if they are truly only insight....buy one and mail it to the guys at GC
You get the above info and they most likly fix you up.
Old Apr 23, 2010 | 10:08 AM
crx(gator)'s Avatar
wtf are you talking about...Ground Control said they wanted to see a car. why the **** are you in this thread stirring crap for no reason. a) i dont have a corner weight scale, and if i wanted to buy one, it woudl cost more than teh coilovers...
Old Apr 23, 2010 | 01:14 PM
shifty35's Avatar
I want a set.
Old Apr 26, 2010 | 09:46 AM
mustclime's Avatar
I was giving you a option since noone wants to help you....
If you took the time to get the info and produced it for GC, they could assemble a kit because those are the steps they will take to make the "kit". As for the scales....no big deal, just call up your local scca chapter and ask if there is anyone that might be willing to help you out.
good luck with your project....If you are just looking for that hella flush look, just take a sawsall to your springs, you can always order some new ones from honda. No need to worry about the ride, dropping the insight will kill the handling anyway
slimstajimsta5
Suspension & Brakes
May 17, 2005 05:48 AM
DissidentCivic
Jan 19, 2004 06:54 PM
EGh22aEG
Mar 13, 2002 09:57 AM
ActiveAero
Jan 16, 2002 07:18 PM
AfEn808
12
Dec 11, 2001 06:24 AM
