DA oil pressure switch, remove trunk hole filler panel
Old Apr 15, 2010 | 02:09 PM
NayborhoodJohnny's Avatar
Default DA oil pressure switch, remove trunk hole filler panel
i have a 92 integra....
i need a new oil pressure switch... they are cheap but are they easy to install? anyone know how to install them?
i also got my rear trunk hole filler panel kicked in and i got a new one to replace... anyone know how to remove this piece of my car?
Old Apr 15, 2010 | 08:07 PM
Honda_ThuGZ's Avatar
Default Re: DA oil pressure switch, remove trunk hole filler panel
oil pressure switch should be easy just get under the car and look for it
it should be around the oil filter area its a 1 pin connector just disconnect that and unscrew(i 4got what size socket it is)
to remove the filler panel u gotta take ur taillights out and the rest are 10mm bolts
Old Jul 1, 2010 | 10:55 AM
thanks a lot!
jens0771
10
Apr 20, 2014 06:20 PM
94civicex.
Sep 17, 2010 11:47 PM
aznevanchoi
Aug 24, 2007 11:58 PM
aw_wolfe
Jan 27, 2005 12:30 AM
wwcivic
Sep 7, 2001 10:37 AM
