f22b vtec only goes to 2000 rpms an starts sputtering cutting in an out ?
Old Apr 15, 2010 | 12:56 PM
newmarketcb7's Avatar
Default f22b vtec only goes to 2000 rpms an starts sputtering cutting in an out ?
its a 91 cb7 lx auto trans and f22b sohc vtec out of a 97 honda accord ex OBD-II motor in a OBD-1 car with the f22a wire harness, ecu ,f22a dizzy external coil ,92 map sensor. the codes i got was 7 fast, 2 slow,4 fast,5 slow
can seem to find any codes so if any one can plz help that would be wonderful it suck not having a car i didnt want to do the swap but had a low mile motor in my wrecked 97 accord so didnt spend alot of money into the swap just a a to b ride to see my son an to work here is a video so u can see an hear what it is doing http://www.youtube.com/watch?v=KleumsnqdaA
thank every one that will take the time to help me and **** all the bitches that didnt say **** an knew what me problem was
Old Apr 15, 2010 | 04:18 PM
imbodiedchaos's Avatar
Default Re: f22b vtec only goes to 2000 rpms an starts sputtering cutting in an out ?
I don't know too much on the CB accords but I recommend going to an Auto Zone or Advanced Autoparts (or something similar) and purchasing a Haynes Manual for your car. Typically these stores have a section with books and each manual is specific to the year range of the model, ie, I bought one for my 94 accord and it covers 94-97 Accords. Its relatively cheap. It has a list of engine codes in there that tell you what the code means.
count the slow flashes first then the fast.
2 slow, 7 fast Code= 27
5 slow, 4 fast Code=54
Being OBDI there shouldnt be a difference in the codes and meanings. Not sure how the swap will affect this if it does at all. Let me know how much help this was.
Old Apr 15, 2010 | 04:23 PM
well i figure the prob out just 20mins ago its driving great throwing two codes but im loving this i got my car again i post i vid tomorrow to show yall how she is now thank everyone for there help this has been a long project but now i can enjoy all the time i get wit my son
Old Apr 15, 2010 | 04:35 PM
GhostAccord's Avatar
There is no such thing as obd code 27 in the Honda OBD codes & code 54 is for a crank fluctuation sensor, OBD1 Accords do not have a CKF that I know of.
The way you have it written above it would be codes 7, 24 & 50.
7 = throttle position sensor
24 = Non Honda Diagnostic Trouble Code
50 = Non Honda Diagnostic Trouble code
You need to post up a video of your cel flashes or tell us when the pauses are between the flashes. You will see that the codes continue to repeat themselves. tape it for a minute to get all of the codes.
Now if they are legit codes 24 & 50 that could be a sign of a bad ECU.
by the way you didn't have to start a new thread
Old Apr 15, 2010 | 05:05 PM
I wasnt sure about the codes, I dont know all the codes for OBDI Hondas thats why I recommended the Haynes Manual. But thanks for the correction.
I agree about video taping the flashing cel light. Multiple codes flashing in sequence can be tricky to describe
Old Apr 16, 2010 | 05:20 PM
TheCirclingSky's Avatar
so what exactly did you do to fix this problem, the help would be appreciated cause i am currently having the same problem
Old Apr 16, 2010 | 06:27 PM
Is your check engine light on? if it is you need to retrieve the codes from the ECU.
Slammed95Cord
Jun 13, 2012 03:35 PM
silveraccord2000
Aug 20, 2008 01:41 PM
accordparts96
Jun 17, 2005 11:57 AM
SupaFly
Jan 2, 2005 07:15 PM
bigga71
Apr 30, 2004 10:22 AM
