Problem with TPS sensor. Code 7.
1989 civic hatch with a B18B.
Today I was driving and someone comes up to race me, we race and i beat him and I look down and a solid CEL comes on. I drive home and notice my car is idling at like 1200. I get home, shut the car off and turn it back on and everything is fine and the CEL is gone. So I'm like hmm I wonder what made the CEL come on, so I jump the ecu. I'm pushing a code 7 which is the Throttle Position Sensor. I pop the hood and its plugged in. I start the car, its running fine, no CEL, and I unplug it. Idle goes up and the CEL comes on. so I shut the car off, plug it back in, and start the car. No CEL and its running fine. I jump the ecu again and its still pushing a code 7. So the CEL isnt on anymore, its running fine, but the ECU is stil pushing a code 7, and what would make it just come on at the end of a race?
It is possible that you damaged it, im not sure how.
i unplugged the battery for 10 mins and plugged it back in and jumped the ecu and no code 7...weird
Leave the TPS plugged in, turn car off, unplug fuse, plug it back in, and you should be good to go.
I could be wrong, but the shock of going from a close, to wide open throttle. I could have given out the wrong reading causing the CEL to show up until the readings were normalized.
well he just came up next to me and tried a ricer flyby on the shoulder and i used half throttle to catch up to him and once i got next to him i hit full throttle
I honestly dont know man, if it doesnt show up again then fine. But if you want to test it out, go on an empty street and go to WOT suddenly and see if it happens again.
Check and make sure all your connections from the tps to the ecu are all snug and you are not getting a short. Id also check with a multi meter since I'm sure you don't have the proper machine to do a full sweep and graph the tps to make sure it isn't faulting in a certain area. But get a DMM and test the tps, ignition on it should show .5v to pins c7 and c 12 at the ecu.
Mugen112
Jun 12, 2009 09:50 AM
jbiel
11
Jan 11, 2009 06:27 AM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
