gsr block with type-r head?
okay guys i got a jdm b18c gsr with the stock gsr head. now if i was to swap the gsr head for a type-r what hp, tq throttle responce would i have. also any other advanages or disadvanages.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/gsr-head-si-head-would-better-2760437/
rather than waste the money on the R head, port the gsr head, do valvetrain and get the throttle body bored out, all that would probably cost about the same as a complete type r head and flow and perform better
@ cain marko why u got to put me on the spot bro when u been here since dec 03 and u dont realy know sh!+ bout hondas u said in the other thread i made ( the links above) that the b16 would rev higher hows that when the ecu is what makes the motor rev higher stay off my posts if u dont know what u talkin bout also the head has little to do with the compression its mostly the block jus so u know
also the block has zero to do with compression, its more about the dome of the pistons, size of combustion chambers, thickness of the headgasket, if the head is milled or not, if you have high compression valves or not, and every little bit counts, it could mean the difference between needing race gas or not, but i am sure you knew that too right?
The one on the left is a B16/Type-R head. The B16 and ITR head are the same except that the ITR head is mildly ported and polished, has slightly more aggressive cams, and dual valve springs on both the intake and exhaust sides. They are both stamped PR3. You'd know this if you actually read your other thread about your B16 head, but I digress. The one on the right is a GSR head. Notice the differences in the size of the chambers. If you don't think your compression would change, then you need to go back to school and take a physics class.
it's called a poorman's type r.
And since you know more about honda than guys that have been here for years, I'm sure you already knew that and can find the answers yourself.
And just so you know.....Pistons and CC's play a bigger role than the block in itself.
I mean get real dude, do you see people buying "High compression engine blocks"
or do you see them buying High CR pistons, rods, crank and heads....
A little food for thought, be nice, it will get you a long ways and people will be more apt to help you out.
op, that is absoluty no reason to talk to someone that is try to help you, and clearly knows much more then you do.
I also agree with cain Marko, if im not mistaken a gsr has a little smaller combostion chambers that could bump up your compresion a bit.
i had the same problem with the OP on his other multiple thread. He pm'd me mouthing off after i posted a couple good bits info to his questions.
He's just rude!!
He's just rude!!
grammer owns you man. The only idoit that i can see in this thread, is yourself.I think you should just step away from your keyboard, and sit on your hands. Each and every post you make, makes you out to a be a retarded ungreatful **** head. You know noithing about what your trying to talk about, Im guessing thats the reason you created more then one thread.
He just showed you, not told you, that the head plays more into Compression Ratio(try using the correct terms) than the block.
If you know so much about hondas and engines in particular, WTF are you doing here asking us for help.........
[QUOTE=Cain Marko;42188371]www.tuneruniversity.com/forums/showthread.php?t=1900, stock for stock the b16 head is CAPABLE of revving higher, sorry if i didnt word my post correctly for your peanut sized brain to process
also the block has zero to do with compression, its more about the dome of the pistons, size of combustion chambers, thickness of the headgasket, if the head is milled or not, if you have high compression valves or not, and every little bit counts, it could mean the difference between needing race gas or not, but i am sure you knew that too right?[/QUOTE
okay a stock b16 has the same rev limiter as a gsr. i have a gsr and i goto 8000 alday and remember u said b16 which is a si you said nothin bout a type r head idiot.
jdmstyleEJ6
39
Apr 17, 2010 07:03 PM
92eh3si
Jul 4, 2004 08:53 AM
BI8B
Sep 11, 2003 08:38 AM
