What would make a good, fairly thin, flexible thermal barrier (in ~1' X 1' sheets)?
Difficult to say without knowing the intended purpose.
Ah, yes, I know what you're talking about.
You might want something more substantial than the foam heater pipe wrap. I'd be afraid of it melting into goo between the valve cover and the IM.
Good point, but I thought that stuff was good up to and above 100 degrees C?
Anything else I could use? Exhaust wrap might work, but I have to cover a pretty big area.
How much space is there between them?
It may be that the best thing would be to not put anything there at all. Trying to insulate it may actually accelerate heat transfer. If there is sufficient space between them the air in that space may help keep things cool.
There is about 1/2" at the tightest spot and the rest has about 3/4" clearance between the valve cover and IM. Might be too thin to put a barrier like pipe wrap in there.
Maybe I should just get a home ceramic coating kit and coat the valve cover and the under-belly of the IM.
BlUeHoOdCiViC99
13
Dec 22, 2005 10:24 AM
wicked4u2c
May 8, 2004 05:20 AM
