Tie Rod job
Old Apr 15, 2010 | 08:30 AM
JDM-KIDD's Avatar
Default Tie Rod job
Im doing my my Tierod (front Left) and i was just wondering was there a way i can replace the tie rod with out messing up the allignment or is there no Saving it... and also.... Dont i need to put Grease on the threads of the tierod so its not metal on metal.... thanks for all the help guys....
Thank you
Old Apr 15, 2010 | 08:41 AM
ef_cowboy's Avatar
Default Re: Tie Rod job
dnt put grease on the threads but count the times u turn it and put it back on that many turns and u should be close to what it was at.
Old Apr 15, 2010 | 11:08 AM
jonnyt1130's Avatar
When your taking it off you can usually see the line where the rust stops on the threads where the end of it stops. This is just a way to use it as good judgement but i would still reccommend an alignment.
Old Apr 15, 2010 | 11:10 AM
JDM-KIDD's Avatar
Thanks guys I was told from my bro (he mechanic) i should use Grease..... i dunno if he ment fro tierod or control arm i think it was tierod...
BIGef
20
May 5, 2013 03:38 PM
Brownjd
May 23, 2008 04:57 PM
gsr2envy
Nov 8, 2004 11:58 AM
chad174
16
Apr 7, 2003 08:02 PM
arcticblursx
Mar 29, 2003 01:00 AM
