Heeeeeeeeelllllllllllllllpppppppppppp
Old Sep 10, 2002 | 11:55 AM
Typel2's Avatar
Default Heeeeeeeeelllllllllllllllpppppppppppp
Can you tell me how to make my horn to work??? i have a Momo Champion Steering wheel... i did a search already.. nothing comes up ..
please use more simple terms... i have no idea what's "ground wire" or somethiing else .. please just tell me exactly what i have to do instead of explaining how to do it .....
thanks in advance.
oh. a picture would help.. thx
Old Sep 10, 2002 | 11:57 AM
Reid's Avatar
Global Moderator
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (alvinl)
Do a search for "horn" in archived threads.
There's a wealth of information there.
Why do people keep lying about doing searches?
Old Sep 10, 2002 | 11:58 AM
SurferX's Avatar
Those terms would be good to learn before tearing up your car...
Old Sep 10, 2002 | 12:03 PM
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (SurferX)
if you did a search.. you will see i post this topic before... all those answer are very general.. i am having trouble understanding "the language"..
Old Sep 10, 2002 | 12:05 PM
Big Phat R's Avatar
If you don't know what a ground wire is - why the hell are you doing this yourself?
I have a solution - drive with your window down and yell "beep beep!" when someone gets in your way instead. Can't make it much more DIY than that.
Old Sep 10, 2002 | 12:06 PM
yoshi234's Avatar
I shoot brides
https://honda-tech.com/zerothread?id=256296
yoshi234 - who did a search and found a good thread in 18 seconds
Old Sep 10, 2002 | 12:08 PM
Trey's Avatar
25 Year Member
If you are having trouble understanding the language (english) take it to a professional.
It's VERY simple.
Two wires are involved to complete the circuit. Ground (-) goes to the chassis (metal). Positive (+) goes to the horn lead. Get a circuit tester to find the horn lead and go from there.
If you can't install your own aftermarket radio, you shouldn't be doing this by yourself.........
Old Sep 10, 2002 | 12:10 PM
sgT's Avatar
sgT
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (Trey)
http://hometown.aol.com/llucas7086/5gwheelinstall.html
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (yoshi234)
after i have found which one is the horn wire, do i just simply connect it to the back of the horn??
Old Sep 10, 2002 | 12:44 PM
Comp97GSR's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (sgT)
and this is what to do if you get a JDM non srs s/wheel noobs
Old Sep 10, 2002 | 01:31 PM
4-1-1's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (Comp97GSR)
My horn is not working and i don't give a **** lol............
Old Sep 10, 2002 | 01:33 PM
D's Avatar
D
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (Big Phat R)
oh chit! LOL!
Old Sep 10, 2002 | 02:13 PM
01CWITR's Avatar
that's funny !!
[Modified by TillerMan, 11:14 PM 9/10/2002]
Old Sep 11, 2002 | 01:25 AM
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (D)
Can you show me a picture ?? a picture of that cable or something ..
Old Sep 11, 2002 | 09:25 AM
owen_the_soyboy's Avatar
Oh shiiiiiiiiiit. All you need to do is connect the horn wire to the horn button and ground the other connector out of the horn button.
But of course you need enough wire wrapping loosely around the shaft so that it does not wrap tight and snap apart when you turn the wheel. You can hack into the oem cable reel (the black plastic assembly that turns around and around with wire inside) if you are ambitious. I did and it took me about one hour to get it all finished. I had to cut the cable reel plastic housing so that it is only half as tall as it started. Meaning it need to be a half inch think so that the sparco steering wheel hub will bolt tightly to the steering shaft. So I removed the wires from th ecable reel and got out a dremel cutter and then sliced it in half, just like a pepperoni slicer and I kept the bottom half. Then you need to determine which wire is the horn wire, I found mine by removing the airbags then trying to ground different wires one at a time. Then you need to split the 7-wire (or whatever) casing down the middle with a knife, yes cut it in half for the entire 10 foot length or whatever it is, yes its LONG! Keep the half with the Horn Wire of course . Now play with this wire a bit to bend it in the right direction to head up the base of the Hub to the brass colored metal disc piece at the bottom of the Hub. I removed this brass disc, slipped the one wire for the horn up against the hub, then slipped the brass disc back onto the hub.. this anchors the wire to the hub so that it will not get pulled out when you turn the wheel. Now make sure you solder this horn wire to the wire soldered on the topside of the brass disc... this was easier than soldering the wire to the disc directly. Why? -->Because you need super hi temp solder to do that and the pre-soldered wire there on the disc had a few areas I was able to solder to. Now run the pre-soldered wire from the Hub to the horn button. Attach a new piece of wire about 4 inches long to the ground connector on the horn, then to the ground connector on the Hub (Hub Ring). Plug in the battery and check that ****. Mine worked like a charm. Now make sure you have the cable reel oriented correctly (meaning you have enough slack in the wire to allow a few turns in each direction), then bolt it to the column. Then attach the Hub to the column, then the steerign wheel. Taa daa, you are fini~
You get bonus points for installing Hella Twin Supertone Honrs at this time as well.
I know you WANT pics, but I cant guarantee I'll get them anytime soon.
Old Sep 12, 2002 | 05:13 PM
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (owen_the_soyboy)
eeeeeerrrrrrrrrrr.... PICPICPICPICPICPIC
Old Sep 13, 2002 | 12:29 PM
lol
I'll try to post 'em tomorrow, chum
Old Sep 13, 2002 | 07:40 PM
Typel2's Avatar
THANK YOU THANK YOU THANK YOU!
Old Sep 18, 2002 | 12:31 AM
Typel2's Avatar
pic!!!
Old Sep 18, 2002 | 06:19 AM
BudMan's Avatar
It might be worth checking on the gsr hub behind the steering wheel. If it's like the civic dx & civic ex, the one WITH cruise control has metal contact-canals for constant contact so no wrapping of wire is needed. Obviously, you aren't using cruise control, so you don't need to use it for that.... (I used it those canals to hard wire cd/radio controls to the cruise switch on the EX steering wheel.)
Now that I've said that - PUT A MOMENTUM SWITCH FOR THE HORN ON THE FALKING DASH!!! Who wastes time honking the horn when you can just move your **** out of the way??? Then push the horn button on the dash.
Old Sep 19, 2002 | 10:12 PM
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (BudMan)
i can't believe no one here has picture.. or draw me some graph.. do something to help me please .. helllllllllllllpppppppppppppp
Old Sep 19, 2002 | 10:13 PM
nEoMuGen's Avatar
Worst comes to all, just roll down your windows and vocally manipulate the sound of "beep".
Old Sep 20, 2002 | 03:59 AM
Typel2's Avatar
Default Re: Heeeeeeeeelllllllllllllllpppppppppppp (nEoMuGen)
haha.. your joke is not funny .. haha
Uljima
May 4, 2014 10:24 AM
b18crx88
Apr 9, 2008 11:44 PM
superdat1
Sep 3, 2007 10:32 PM
Tiwe
Sep 28, 2002 08:40 AM
lsvtec42
Feb 4, 2002 09:20 AM
