d15b or b16a?
So, I have this little situation and I wanted to get some opinions. I am deciding to swap my eg with a jdm d15b or b16a, but I don't want to deal with smog/ref a lot. I'm leaning more towards the d15b, because of the easier swap and the motor of my d15b8 is pretty much equivalent to the d15b, which I won't have to deal with ref. But I am getting a lot of people saying to go with the b16a, because of the more power and that it would be more worth my money to invest in the b16a. So, now I am stuck in the middle again and wanted to hear some of your opinions. Basically, I want to hear how you guys would go about it and how would you deal with smog/ref. Thanks in advance.
B16 all the way *** single slams if u do ur swap correct and harness is wired up correctly with correct ecu and no check engine light and motor is in good conditions u wont have a problem
There are no more smog refs in CA. Therefore, if a cop asks you to pop your hood and it's not an engine that came from the factory (or equivalent replacement), it's illegal. No questions asked - You get a fat fine, end of story. There's no BARing the motor anymore - you'll just have to hope you don't get your hood popped, as well as hope you have a smog tech that will work with you when it comes time to register your car bi-annually.
The b16 swap won't be much more difficult than the d15. Usually if someone says they don't care which choice they make, I say go with the cheaper one but I just can't bring myself to here. They've become a little outdated now but the b16's were impressive motors imho.
Yes. It looks stock so won't raise any flags if they choose to pop your hood. I've been fortunate enough to have only been popped twice and only ref'd once (by an ill-informed officer). If it looks stock, no crazy intakes, header, FPR or anything that doesn't look 100% factory, they won't ref you.
And the d15b is like the d16z6, not the d15b8.
As far as the swap goes, move out of Cali and get whatever the hell you want... I hate Cali... My vote is for the D15B though.
Not really the obvious choice in terms of bang for your buck or in terms of ease of install.
D15B is a good motor with adequate power and will net you great gas mileage. Also, it is the least likely to get noticed if you do get asked to pop your hood.
You can make some B16's legal in Cali. Do a bit of research and your labor will pay off in the end. So with the B16 you can have an engine that is legal, even if it looks like it isn't.
On the other hand, D15B will, to the best of my knowledge *never* be legal. Almost no way in hell. It will *look* legal but never be it.
So on one hand you have an engine that might get the evil eye, but you got the paperwork to defend you. On the other you have an engine that might not raise any eyebrows, but if you do end up getting caught, you're effed.
And there is more. You actually can modify the B16 legally as long as you buy parts/kits that are 50-state legal. These parts will have a CARB Exemption number. As long as you install the parts as listed and keep the paperwork, you will be safe.
On the other hand, if you were to get equivalent parts for the D15B, they would not be legal even with CARB E.O. #'s because they are not on the engine they are exempt for. You could get in major poopie for that.
In my opinion, all signs point to B16'age. BTW, I mean USDM B16's. Only way to make it legal. You can do it as long as the engine meets the standards that were set forth at the time of vehicle manufacture. Basically the engine has to be newer then the vehicle it is going in.
Last edited by Korman; Apr 15, 2010 at 05:19 PM. Reason: Specify USDM engines only
