rear shock lower bolt....NEED HELP ASAP
Old Apr 14, 2010 | 12:25 PM
wes_foll_99si's Avatar
Default rear shock lower bolt....NEED HELP ASAP
so im replacing my srings with adjustable ones and i started on the rear cus i thought i would be the easiest. so i loosen the passenger rear lower bolt of the shock and the nut cam off but the bolt is stuck. the bolt spins but is stuck in the bushing/hole. i tried hammering it out but wouldnt budge.....am i missing something here???
please help i am lost
Old Apr 14, 2010 | 02:03 PM
b18c195's Avatar
Default Re: rear shock lower bolt....NEED HELP ASAP
its a known problems with these cars. You are not gonna like my answer but i had to torch mine off.
Old Apr 14, 2010 | 03:33 PM
TonyRomo's Avatar
Torch it, cut it, whatever needs to be done but that's what we did while changing mine. ****in pain in the ***, I wish I had just paid a shop to do change my shocks.
Old Apr 16, 2010 | 02:44 PM
DOHc SIdE's Avatar
Just wait, buy aftermarket shocks and blox lca's cause your just gonna blow the factory shock anyway if you lower it on them. Its sounds like alot more money but you'll save money and time in the long run.
Old Apr 16, 2010 | 03:27 PM
Local's Avatar
Use a Jack to take some pressure off try wiggling it around
Old Apr 16, 2010 | 03:36 PM
DAintegraGSR's Avatar
if its just stuck and the bolt hasn't broken yet... just take hammer and force it out of the hole.
irideslammed5021
12
Mar 28, 2007 04:02 PM
96tegman
Jun 8, 2006 04:16 AM
2Point2EH2
Apr 25, 2006 10:36 PM
CivicEK.PDX
Sep 12, 2002 06:42 PM
94CivicSi
Mar 24, 2002 05:21 PM
