Fuel tank drain bolt
Old Apr 14, 2010 | 11:07 AM
sloassSi's Avatar
Default Fuel tank drain bolt
Does anyone have a picture of where the fuel tank drain bolt is? I have 2000 civc, and need to drain the gas out it. My tank is sprayed with under coating and I have no idea where the bolt is located... I was told my car had the bolt to drain the tank, is this correct?
Thanks for your help.
Old Apr 14, 2010 | 11:55 AM
sloassSi's Avatar
Default Re: Fuel tank drain bolt
anyone?
Old Apr 14, 2010 | 12:04 PM
RICKSAUTOMOTIVE's Avatar
your car shouldnt have that much undercoating. look for a big bulge-then clean it. that has to be the plug. some cars however do not have drain plugs. the plug will be on the lowest point of the tank--so it would drain
Old Apr 14, 2010 | 12:11 PM
dpetro1's Avatar
Old Apr 14, 2010 | 12:52 PM
andrewk's Avatar
IT SHOULD BE BY THE REAR DRIVER SIDE LCA SHOULD BE A BULGE BRAKE CLEANER OR SOMETHING AND A WIRE BRUSH AND OPEN YOUR GAS CAP THEN OPEN THE DRAIN BOLT
Old Apr 15, 2010 | 10:11 AM
sloassSi's Avatar
I found it... thanks for the diagram and all of the explanation.
NJcoupe
Apr 22, 2007 02:12 PM
allnaturalb16
Jan 13, 2007 01:17 PM
heretolearnandteach
Oct 22, 2006 12:58 PM
boostedK20a2
Jun 20, 2006 08:36 AM
tonezilla
Sep 11, 2004 04:33 PM
