how to remove a torque converter???? HELP
Old Apr 14, 2010 | 09:24 AM
oskarsEG6's Avatar
Default how to remove a torque converter???? HELP
im replaceing a engine for a friend but i got stuck on how to remove the torque conerter, does anyone know how to remove it?
HEEELLLPP PLEEAASE
Old Apr 14, 2010 | 10:07 AM
RICKSAUTOMOTIVE's Avatar
Default Re: how to remove a torque converter???? HELP
HEEELLLPP PLEEAASE
remove the lower transmission flex plate cover and turn the motor over by the crank bolt a little at a time to get the torque converter bolts out. it has been a while since i did it my self but you might be able to get them out from the starter hole as well. i know thats the other side of the flex plate but for some reason i think the last one i did was like that on a acura vigor. i know the vigor is a whole different car with a 5 cylinder front wheel drive and an axle shaft passing through the oil pan but it was a honda so maybe others are like this also. that was an automatic trans obviously but it was the last automatic trans i removed and that was like 18 months ago
Old Apr 14, 2010 | 10:14 AM
oskarsEG6's Avatar
ok thanks that wired this is the first time i do a automatic swap so its a whole different story for me lol thanks btw......
Old Apr 14, 2010 | 10:27 AM
no problem. pm me if you get stuck. i'm guessin youre doing this without a repair book LOL. i check the post throughout the day so you shouldnt have to wait too long if youre stuck. i literally check posts about 40 times a day at a minimum
johnnyabq
Honda CR-V & Element
Aug 29, 2012 07:48 PM
JusAccord
Jul 17, 2011 07:36 AM
EGbeater
Oct 28, 2005 10:29 AM
dbailey
Sep 26, 2004 02:07 PM
BigZ88
Aug 14, 2003 07:01 AM
