B16A1 or D15B on EG hatch?
From: Quezon City, The Philippines, The Philippines
I am having a hard time choosing what engine will I install on my EG hatch. The B16A1 is not a bolt-on, but still it is a B-series engine. On the other hand, the D15B is a bolt-on on my EG hatch however, it is only SOHC unlike the B16A1. Besides, I am also planning to install a B16A2 later on, it would save me a lot if I will choose the B16A1 since most parts, if not all, are interchangable with B16A2. The D15B is a different case, I can't use everything that I will purchase for it on my B16A2 in the future. Please help me, thanks!
Well I would say the B16a1 (rrraaarrr), it's an easy choice for 160 hp
, I don't know why you would swap to the a2 later on though. It's only ten more horsepower, the difference is the hydro tranny, but why waste your money on an a1 swap now?
Go witht the B16A1 or 2.They are both better then the D15B.I have a D15B in my hatch and it sucks big time so im swapping it out for a B18B.If you had to go with a SOHC then go with the D16,its a SOHC vtec and alot better then the D15B,if im not mistaken and i could be wrong but i think the D15B only has around 70hp,and the D16 has around 125.Good luck with whatever you go with.
Yea use the d15b i believe he is talking about the jdm one as well, and then save for a b18c, or an b16a2 swap
get the b16a... dont even think about the d15.... a bunch of bs.......if you want you can save a tad bit more money for the A2, of if you want you can do what i did.... mat the 1st gen motor with a hydro.....1st gen fu
ing rule!
ing rule!
