I got coolant in my cyliner
Old Apr 13, 2010 | 06:54 PM
EKferio 808's Avatar
Default I got coolant in my cyliner
hey guys i just rebuilt my motor and theres coolant in the cylinders. i got the head shaved and pressure tested and it was good. got a new head gasket and all. idk whats wrong can someone plz help
Old Apr 13, 2010 | 07:20 PM
RICKSAUTOMOTIVE's Avatar
Default Re: I got coolant in my cyliner
did you use a honda head gasket? did you torque the head in the correct sequence? were your head bolts stretched? (i always replace them with new ones) were the head bolt threads stripped at all? some of the hondas have issues with this when the engine has been overheated. particularly the 1.7 and 1.6 honda engines and northstar engines. this is only in some cases also so keep in mind that you may not have this problem. was your block cracked anywhere? was the cylinder head deck warped?
Old Apr 14, 2010 | 10:31 AM
Everything was tested and checked out good. i torqued the head down properly. brand new honda head gasket. the block is good. the weird thing is all 4 cylinders look exactly the same. there are not flooded with coolant but you can see that thier a little moist. spark plugs arnt wet either when they were pulled. do you think i might just have to run the car for a while?
Old Apr 14, 2010 | 11:35 AM
92 CiviC H.B's Avatar
same thing happened to me.rebuild my engine and had a lot of water in 4th cyl. i replaced the head gasket since then its fine.not sure why it happened but it did lol.
Old Apr 14, 2010 | 12:08 PM
do you guys think theres somthing wrong with my torque wrench? i have the needle type. should i borrow one of my friends one? do you think maybe the head isnt getting torqued down right?
Old Apr 14, 2010 | 12:56 PM
yeah i would get a new torque wrench. my grandpa used one with a needle but my snap on is more accurate
Old Apr 14, 2010 | 06:16 PM
thanks guys ill try it and let you know how it goes
Old Apr 14, 2010 | 07:01 PM
used the new torque wrench but now about three of the head bolts are squeeking when im tighting them. they dont twist smooth like the others. are the bolts no good?
RyanA
Jun 1, 2017 05:10 PM
94 Civic Si
Engine Machining & Assembly
23
Apr 23, 2017 07:15 PM
ArtyTheKid
Feb 25, 2013 08:29 AM
ej8ster96
Sep 15, 2011 02:44 PM
fiftee_su
Oct 8, 2003 09:23 PM
