Slammed Lude Camber Kit - Ball joint or Anchor style Ingalls?
Old Apr 13, 2010 | 07:35 AM
professorman's Avatar
Default Slammed Lude Camber Kit - Ball joint or Anchor style Ingalls?
I am looking for a camber kit for 97 Prelude SH. Should I get the anchor style or the ball joint style?
I bought the Prelude slammed, and I am not sure what type of springs are on there, but it is pretty low. My exhaust resonator scrapes over speed bumps. I have had terrible tire wear problems, even though I get the car aligned all the time.
Would the Ingalls ball joint style of camber kit cause travel space issues? It seem like the ball joint might be better build quality and easier to adjust, and I might even be able to adjust it myself.
What do you guys think?
Old Apr 13, 2010 | 12:16 PM
LudeLooker's Avatar
Default Re: Slammed Lude Camber Kit - Ball joint or Anchor style Ingalls?
I think you should probably invest in a quality adjustable suspension and put it at a reasonable height. But I don't know much....
Old Apr 13, 2010 | 03:26 PM
bad-monkey's Avatar
Get a set of ground controls and raise the car to a reasonable height. then align it and zero out the toe and don't worry about the camber. Your tires won't instantly die because you've got -2.5 degrees of static camber and 0 toe.
Old Apr 14, 2010 | 01:09 AM
Kronn 98SH's Avatar
^ What the permed mullet said.
Old Apr 14, 2010 | 01:40 AM
dagle's Avatar
I would get decent suspension before a camber kit, thats for sure.
Old Apr 14, 2010 | 07:02 AM
vansprinkle's Avatar
if you are too low, the ball joints can cause suspension travel problems.
Old Apr 14, 2010 | 07:15 AM
NirVTEC's Avatar
x2
If you need a Camber kit, your car is too low or something else is wrong/broken.
^^That will be my response to everyone from now on^^
jmai86
Suspension & Brakes
Jul 27, 2009 04:58 PM
hondaluver12
32
Dec 17, 2008 08:11 AM
FLACO EM1
Nov 27, 2008 01:39 PM
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
