LS starter questions!!!!!
ok so i have and obd2 b18 ls engine and a ys1 cable ls trans. the engine is gunna be running obd1...but the b18s were hydro trannys then.....so what starter do i use for my car the 90-93 starter...or the obd1 starter...will the obd0 hook up the same as the obd1 starters..?
startes usually only have two connections... as long as it bolts up u can make it work.
I dont recall but im pretty sure even the g2 tegs had the same starter despite being a cable trans.
