Timing is off, dizzy is turned all the way...HELP
Old Apr 12, 2010 | 07:13 PM
iigrafixii's Avatar
Default Timing is off, dizzy is turned all the way...HELP
I just got my car smogged and my timing is at 20 BTDC. My distributor is turned all the way to the left. The white mark on the crank pully is lined up with the pointer and the up mark is up with the other lines level with the head. How do I adjust the timing if it wont go any further?
Old Apr 12, 2010 | 07:15 PM
iigrafixii's Avatar
Default Re: Timing is off, dizzy is turned all the way...HELP
BTW it's a '93 del sol with a z6, 198k miles, timing belt done at 180k, auto
Old Apr 12, 2010 | 07:39 PM
forcefedferio's Avatar
sounds like your base timing is off, your car should run at 16 degrees advanced timing and if you are maxed at 20 degrees BTDC something is mechanically off, you will never compensate for that by pulling ignition timing.
Old Apr 12, 2010 | 07:53 PM
iigrafixii's Avatar
So I should pull off the t-belt and check the marks right?
Old Apr 12, 2010 | 08:22 PM
yes
Old Apr 12, 2010 | 08:23 PM
egsleepercivic's Avatar
yes this most likely the issue
Old Apr 12, 2010 | 09:50 PM
iigrafixii's Avatar
I was afraid of that. Thanks guys
dem0nk1d
Jun 27, 2012 12:39 PM
EX-T
Jan 21, 2009 04:16 PM
kixcrx
Nov 10, 2006 10:33 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
