What bias-ply/radial for 6-700hp+ on the street?
Old Apr 12, 2010 | 07:12 PM
Pumpking.'s Avatar
Default What bias-ply for 6-700hp+ on the street? MT ET or QTP?
EDIT: Don't mind the rest of the below 1st post. narrowed down my choices... I'll be doing either the MT ET street bias-ply's, or the Hoosier QTP...anyone have any experience with both and can say which performed better?
I know at that point of making that much hp, finding a tire to hook becomes limited, but what are you guys using?
I have my 26" m&h slicks for the track. Now I need something that'll handle street duty.
M&H street/strip DOT's...only realistic size is 235/60/15. Tread width is only 7.5". I'm afraid for my power levels, I'm going to blow these tires off to the moon in 3rd gear.
http://www.mandhtires.com/store.php?...on=show_detail
Anyone use DOT cheater slicks on the street? Theyre the wrinkle wall bias-ply type of radial..
M&H: http://www.mandhtires.com/store.php?...on=show_detail
MT: http://www.mickeythompsontires.com/s...?item=ETStreet
Thing i like about the above 2 tires is the wider, 8.5" tread width and the softer compound for better traction.
Can I install these, inflate them, and drive on the freeway 10-20miles and around town short distances with them? Or is this like a slick where it shouldn't see any street duty?
The main concern for me is the street chewing these tires up. I know they wont last considerably long. that isnt a big deal. i just dont want them chunking up or ripping apart.
On a side note, 225's WONT work. been there, done that. haven't tried 235's, but i suspect they are not going to hold up at all. dont want to spend $320 to find out either..
the ET Street Radial II MT's have a 255, but that's a 27" tire. WAY too tall. looking for a 26" tire.
Since that's out of the way, what are you bigg hp buys using for street duty and having success with?
Old Apr 12, 2010 | 07:20 PM
SwappedTURBOegg's Avatar
Default Re: What bias-ply/radial for 6-700hp+ on the street?
i have put 700 miles on my 235/60/15s and i have seen minimal to no tread wear. every time i drive the car its on the highway 100+ miles
haven't made much power yet so idk how there going to hook up feel good at high 300 tho
Old Apr 12, 2010 | 07:26 PM
TDautowerkes's Avatar
275/50/15
works great!
Old Apr 12, 2010 | 07:34 PM
Pumpking.'s Avatar
Originally Posted by TDautowerkes
275/50/15
works great!
i had my eye on a 275/50 drag radial because of the better life on the street vs that of the Cheater slick.
ONLY reason i didnt pull the trigger for 275s is because the section width of the MT DR's is 11.5"
my M&H 26x8.5x15 slick has a section width of 10.5 and it slightly rubs my coil perch w/ 8mm spacers..
which DR are you using? MH or MT? I see the MH sidewall width is 10.9..hmm...
Old Apr 12, 2010 | 07:39 PM
Pumpking.'s Avatar
anyone good with rim offset differences between 2 different sized rims?
I have 15x8 slipstreams w/ +40 offset for my slicks that barely touch my coil sleeve when i decel.
I also have 15x7 slipstreams w/ +35. do i gain clearance or lose clearance switching to the 15x7 rim? i need more clearance..like ~5mm. im wondering if the slimmer width and larger offset will resolve my issue... :dunno:
Old Apr 12, 2010 | 07:53 PM
Mr. Em1's Avatar
its not the width of the tire that matters as much as the height
Old Apr 12, 2010 | 07:57 PM
Pumpking.'s Avatar
definately want/need a 26" tall tire.
width is a big deal for my application..every .5" matters for clearance problems, in my case. If i can figure out which rim effectively "sits further" away from the wheel well, will help me figure out which way i need to go upon making a tire choice.
Old Apr 12, 2010 | 09:52 PM
BoostR41's Avatar
I have run 235/60/15 M&H for a few years. They get great wear for what they are and I have pulled 1.7 60fts on them with 550whp. I haven't had any traction issues with them at all at my power level
Old Apr 12, 2010 | 10:08 PM
Pumpking.'s Avatar
Any boost by gear setup?
Due to manifold design (wastegate placement) and EBC limitations, I had to put a 18lb spring in my WG in order to reach the boost i want, so I can't launch the car at as low of a base psi as i would like out of the hole.
Good to know you had good experience w/ the 235's at 550.
Old Apr 13, 2010 | 05:08 AM
BoostR41's Avatar
No boost by gear but I do have a high/low button. low is 15psi and it hooks and goes that is 412whp. I have launched them on high boost before and they still hooked pretty well. I believe 1.8 60ft was my best. I have never had any issues with rolling into boost on the highway and them spinning. They have always hooked well on the highway, esp rolling.
Old Apr 13, 2010 | 05:31 AM
HamiltonRex's Avatar
Hoosier qtp, 26" bias ply. There as good as it will get.. Plus there light 17lbs. Don't know how long they will last fwd.
Old Apr 13, 2010 | 11:53 AM
Pumpking.'s Avatar
are bias-ply's typically the same compound as slicks? 17lb is some light stuff.
Old Apr 13, 2010 | 12:47 PM
Call Hoosier, there tech guys are usually pretty helpful.
I don't think its the same compound, but they are wrinkle wall style, and DOT approved. I wouldn't want to take any corners at fast speed though! haha.
Old Apr 17, 2010 | 02:14 AM
Pumpking.'s Avatar
so after doing research, 275/50s wont fit irregardless of what i do.
MH 235/60's tread width is smaller than MT 235/60s, so that wont work. and the MT dr's i dont think are sticky enough to hold up on the street for my power level.
Narrowed it down to 2 options...
MT ET street bias-ply 26x10.5x15 (8.3" tread width/10.5" section width)
http://www.summitracing.com/parts/MTT-3752/?rtype=10
or
Hoosier QTP bias-ply 26x9.5x15 (8.0" tread width/9.5.0" section width)
http://www.summitracing.com/parts/HOO-17415/
anyone have experience w/ both? just want to make the right choice the 1st time...
Old Apr 17, 2010 | 06:24 AM
nonvtecallmotor's Avatar
I ran both Hoosier QTP and the M/T ET Street. The M/T are a better hooking tire, but the sidewalls are very thin and I didnt like them on the street. The hoosier seemed to be the better all around tire. The QTP hooks great, last longer, and is more stable on the street. I just WOULD NOT want to be caught in the rain on those tires. The M&H 235's where a good dry and wet tire.
I went 10.4-10.5's on them.
Old Apr 17, 2010 | 10:39 AM
Pumpking.'s Avatar
THIS, was the response i was looking for. thanks!
seems like the QTP's were overall better from what im gathering from your post...going to order the QTP 26x9.5s this weekend.
thanks.
Old Apr 17, 2010 | 03:05 PM
I mean, AWD, FWD.. whatever, a good tire is a good tire. There is a lot more AWD guys running and going very fast with DOT tires, obviously since there awd.
The 90% of the fast AWD guys run QTP's theres a reason for it too. There badass, and thats all there is too it. I will be running them this season.
b20vtech
Feb 9, 2009 04:18 PM
c-techracing
Jul 9, 2007 09:54 AM
slowsol95
Feb 5, 2007 09:17 PM
gsr98vtec
Nov 6, 2005 08:01 AM
Cyber ITR
Apr 21, 2003 04:54 PM
