I want to buy a set of JDM P73 Type-R pistons
Old Apr 12, 2010 | 06:04 PM
honda_4life's Avatar
Default I want to buy a set of JDM P73 Type-R pistons
I'm trying to built an ls-vtec set up and I was thinking about using JDM P73 11.1 comp TYPE-R PISTONS but I don't know where to buy them for a decent price. If someone can give me some advise I will appreciate it. Thank you.
Old Apr 13, 2010 | 04:01 AM
OH_1fstgsr's Avatar
Default Re: I WANT TO BUY A SET OF JDM P73 TYPE-R PISTONS
Not sure if they are the cheapest but they have them.
http://inlinefour.com/jdmhonoempis.html
Old Apr 13, 2010 | 04:39 AM
trrbl1bmx's Avatar
http://hondamarketplace.com/showthread.php?t=2756857
PM Greasemonkee he has some .25mm OS ITR pistons fs bnib
Old Apr 13, 2010 | 03:40 PM
AcuraLsSE's Avatar
Default Re: I want to buy a set of JDM P73 Type-R pistons
If I was able to do it over again I would have bought the inline four B16A pro cast pistons.
http://www.inlinefour.com/il4peprpi.html
You can get them up to 82mm which would bump your displacement to just under 1.9L. They use the same manufacturing plant as the OEM pistons. Why I would go with the B16A's over the JDM ITR's would be because I would like to know I have a little bit more clearance in between my pistons and my head.
You can use this calculator to see what I mean
http://www.zealautowerks.com/bseries.html
You have .013 clearance over the less .004. Also you would be around the same compression if you use the 82mm pistons. Its also nice that they come with a Molybednum skirt coating. Which the OEM ones didn't.
If I could do it over again I would take this route.
Old Apr 13, 2010 | 07:24 PM
Thank you guys for your info and your time, I really apreciated.
Old Apr 13, 2010 | 10:18 PM
sovada's Avatar
http://www.hmotorsonline.com/shop/sc...age&item=10008
Old Apr 13, 2010 | 11:10 PM
AcuraLsSE's Avatar
This is for the DC5 (RSX)
xQB21x
Dec 18, 2009 02:49 AM
onyx00
Nov 12, 2001 11:26 AM
