1990 Honda CRX Si B16A Y1 Help
Old Apr 12, 2010 | 05:17 PM
tunerimports_85's Avatar
Default 1990 Honda CRX Si B16A Y1 Help
Hi every one I have a 1991 Honda CRX Si with a B16A that I swapped in and got hit by a drunk driver with no insurance so now I finally found another body and am doing a swap thats it so far im doing a half tuck as I dont have the money to do it the way i want YET! but i will ok any how I finished installing everything and went to start it and turn the key and the fuel pump and all the other components turned on turned the key to start it and nothing just the radio relay clicking nothing else for some reason my starter is not even trying to engage ok so here is what all iv done continuity check and i checked and the ignition is getting power if i unplug the other side of the fuse box and put a jumper in the 4 socket plug the starter engages if i use the key nothing happens so im stumped i checked all the relays that are next to the under dash fuse box and all work as i said this car worked 2 weeks ago and now nothing any input would be appreciated here are some more pictures of it so far
Old Apr 13, 2010 | 03:39 PM
EG8R's Avatar
Default Re: 1990 Honda CRX Si B16A Y1 Help
fix your post
Old Apr 13, 2010 | 08:53 PM
Fix what? my title?
Old Apr 16, 2010 | 07:42 AM
FEDONV8's Avatar
they not going to help u need to be straight forward on what u need help with. some of these cats are very uppty. I'm not tho my first car was a 86 teg if u need help pm me.
Old Apr 18, 2010 | 11:09 AM
thanks alot i did finger it out tho its was a combo of my clutch sencer and plug wires on #3#4 were switched
CRX831
Apr 22, 2011 04:50 PM
EatMyVTEC :]
Oct 8, 2010 09:43 AM
patwitahonda
Aug 18, 2009 08:58 AM
JdMcRxSi
Jan 6, 2003 01:44 PM
