Squeaking when braking moderately...
I replaced my right rear brake caliper and pads less than three months ago. they seemed fine but just today I heard an almost metallic squeak that would only happen during moderate braking and it's not a constant squeak. the only thing I could think of is that the rotor is warped but I haven't really done anything that would warp it. I'm also pretty sure it doesn't occur when wet because I've washed it and it's rained after installation and this hasn't occured.
I was going to say you need brake lube on the edges of the shoes, but then I realized you said calipers, indicating you have rear discs...Maybe you need to lube the pins?
R_ACE1
12
Aug 16, 2009 12:53 PM
