help!!! trouble putting gas into car
Old Apr 12, 2010 | 12:26 PM
dc4b20's Avatar
Default help!!! trouble putting gas into car
long story short i have a 90 crx that was given to me by my cousin. its a project car. the gas gauge is not working, it reads between half and full. i was told that its not working and i already ran out of gas while driving it. the problem that im having is that i cant put gas into the gas tank. it will only let me put two or three dollars in and then acts like it is full. but again i know that it is not full. help please!!!
Old Apr 12, 2010 | 05:13 PM
dc4b20's Avatar
Default Re: help!!! trouble putting gas into car
ttt
Old Apr 12, 2010 | 05:24 PM
big-guy 585's Avatar
your not getting the right venting out ur gas tank when ur fillin up next time pull it out of ur filler neck and try putting gas in it
Old Apr 12, 2010 | 07:37 PM
dc4b20's Avatar
i already tried that. i even tried putting gas in the tank with a small gas can and still got the same result. the strange thing is my cousin said he put gas in it before (he didnt own the car that long and it sat most of the time) any other thoughts?
Old Apr 12, 2010 | 09:45 PM
try talking ur retaner off ur sending unit and try it
Old Apr 13, 2010 | 09:57 PM
dc4b20's Avatar
any ideas?
Old Apr 14, 2010 | 05:23 AM
B16-CRX's Avatar
maybe there is something stuck in the filler neck?? I have heard of spiders making nests in there
Old Apr 14, 2010 | 07:56 AM
placid888's Avatar
there's a ball inside the filler neck to prevent gas back float, or prevent people from stealing gas with a tube, just like a one way check valve, the ball probably got stuck or out of position, get another filler neck.
Old Apr 14, 2010 | 09:02 PM
dc4b20's Avatar
thanks for the info ill check that tomorrow
Old Apr 15, 2010 | 03:25 PM
kngcrx's Avatar
Check your Evap canister. It may be filled with gas. I've heard this happens when you top off when you fill up.
Old Apr 15, 2010 | 06:01 PM
JDMchucko's Avatar
you need to inspect/test the vent system on the tank, its the smaller line that runs along the fill tube, check the ball valve at the tank as well. GL
Old Apr 15, 2010 | 08:52 PM
dc4b20's Avatar
thanks for the help. where exactly is the ball valve located at? it seems like it lets me put enough gas in that fills up the filler neck. i can then put a little in and it very slowly will go into the tank and i can keep topping it off just to get gas in it.
Old Apr 16, 2010 | 09:47 AM
dc4b20's Avatar
ok i took the filler neck off and disconected the vent hose from the filler neck. i tried putting gas into the big hose and the gas just poured out of the vent hose. i also stuck a coat hanger down the big hose and it seemed as if it went all the way into the tank. i did the same with the vent hose and i could not get the hanger to go all the way into the tank. so where exactly is the ball valve? my next step is to just pull the gas tank down. any other thoughts before i do that?
Old Apr 16, 2010 | 07:01 PM
dc4b20's Avatar
problem solved. thanks for the help
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
1kleenef
10
Oct 22, 2007 06:30 PM
ekdriven
Jun 8, 2004 08:39 AM
ggangtong81
Oct 12, 2003 06:23 PM
madchiller
Aug 30, 2001 12:47 PM
