How do i switch pins around on harness plugs?
i am talking about, D3. i don't have knock sensor wired up because my wire harness doesn't have a wire for knock.
sorry about the misunderstanding.
can you help me out
can you help me out
so are you just trying to pull that plug out the the ecu plug? if thats the case you can get some pliers and grab the wire way down by the plug and pull on it and the little metal plug will pop out of the ecu plug, i just did this 2 days ago
you gotta be careful when you pull them out that you dont damage them...if you screw them up then the wont go back in the new location..i use a small pick tool and some needle nose plyers..take ur time its lots of fun...good luck
[Modified by jDmDxTuRd, 5:38 PM 9/11/2002]
yeah hes right, i was getting a little irritated about all the electrical **** that was going on so i just ripped them out but they came out ok
haha but yeah you do have to be careful man
I second the dental pick, but if you mess up, you can alway go to a salvage yard and cut a ecu plug off of any honda and use the pins from that. That is what I did.
Crx_Civic
Apr 27, 2008 11:41 AM
quicksilverej6
Mar 22, 2006 05:48 PM
