Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !!
Old Sep 10, 2002 | 08:19 AM
TsunamiZC's Avatar
Default Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !!
i have the supplies i need.....i purchased some transparent window tint spray , and gloss cote from Hobby Lobby ....thats a bad *** store by the way..anyways
whats the best way to do this...do i need to sand it a bit...or just start spraying
i'm not sure how many coats it needs ?
or how long i should wait between coats?
i'm a newbie at spraying ....so any suggestions or ideas ....methods ..etc will be greatly appreciated.....thanks in advance
Old Sep 10, 2002 | 08:23 AM
Big Phat R's Avatar
Default Re: Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !! (tsunami_zc)
DO NOT sand anything - unless you like a frosty look to your plastic.
Spray inside or where there is no wind/no dust.
Rig up a coathanger to hold the pieces you are spraying (so you don't have to touch them while they are wet). Allow to dry in a dust-free area.
You can pre-clean the plastic pieces with alcohol (to remove oil/grease/fingerprints).
Try a couple of coats - let dry - then add more tint to taste.
Add parsley for some garnish and away you go.
Keane Rated R's Avatar
Default Re: Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !! (Big Phat R)
stupid question.. but is it legal in the states?
Old Sep 10, 2002 | 08:27 AM
TsunamiZC's Avatar
koo..thanx alot....how about running or dripping...am i gonna have problems with that....do i spray on light coats ?
Old Sep 10, 2002 | 08:28 AM
Big Phat R's Avatar
spray on very light coats. if things are running or dripping - you're applying too much.
Old Sep 10, 2002 | 08:29 AM
TsunamiZC's Avatar
koo....i'm take a shot at it today ..thanx again
Old Sep 10, 2002 | 08:32 AM
Black R's Avatar
25 Year Member
.....why not just buy the smoked corners for the same price at http://www.importparts.com?
Old Sep 10, 2002 | 08:39 AM
TsunamiZC's Avatar
Default Re: Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !! (Black R)
i already have clears....but i want them smoked, i dont see any smoked lenses on that site...plus its funner to do it my self
Old Sep 10, 2002 | 08:44 AM
RTW DC2R's Avatar
the key is to do A LITTLE AT A TIME...dont try to get the tint you are looking for with one coat...it will just run and be darker around the edges and lighter in the middle. do a light coat or two....let it dry and see how dark it is. the if u want darker, put on another light coat and repeat until dark enough. Also, when u have the lights OUT of the car, its really hard to tell how smoked they look. I would suggest putting them back on after the first coat or two. you may not think the first coat smoked them enough by looking at them while they are off the car, so put them on and see how they look before you go too dark and the look black trust me, i know haha. if you go to dark, paint thinner is your friend.
Old Sep 10, 2002 | 08:52 AM
CPR's Avatar
CPR
Default Re: Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !! (Type Rizzle Fo'
They have a how-to on http://www.team-integra.net. You have to be a member to access it though.
Old Sep 10, 2002 | 08:58 AM
Anderson's Avatar
dude
don't paint it, painting is RICE
are you looking for these?
Order here: http://www.tribalpacific.com/merchan...207&Aisle_ID=4
enjoy
Old Sep 10, 2002 | 09:00 AM
RTW DC2R's Avatar
those are hella dark....
Old Sep 10, 2002 | 09:03 AM
tatty's Avatar
New User
dude
Let him do what he wants...Saving money is not considered rice to me. Granted, I wouldn't put them on anyways, but still.
enjoy
Old Sep 10, 2002 | 09:09 AM
TsunamiZC's Avatar
those do look a bit dark...i'll see how my painted ones turn out...if i dislike it...then i'll buy those
Old Sep 10, 2002 | 09:32 AM
SurferX's Avatar
These are mine I did myself. I think it looks much cleaner than the bright clear or orange look.
Old Sep 10, 2002 | 09:55 AM
TsunamiZC's Avatar
Default Re: Smoked Front Corners ? Need Instructions ? Help greatly appreciated...thanx !! (SurferX)
i just say that on team-integra.net ..looks super clean....
Old Sep 10, 2002 | 11:01 AM
Hooch'n's Avatar
Orange own..............................
Old Sep 10, 2002 | 11:09 AM
MrBite's Avatar
another key to good spray painting is: DON'T stop moving the can when it's still spraying or when it's over the piece. Let go of the sprayer while your arm is in motion or after you've gone off the edge of the piece--this will prevent overspray and runs. Short bursts from the sprayer and quick fluid arm movements are best.
Old Sep 10, 2002 | 11:11 AM
TsunamiZC's Avatar
koo..i guess i'll try to even sprays accros the surface....then let it dry for an hour or so...etc
LudeJdm
14
Sep 18, 2005 11:52 AM
GreenTeaLS
May 31, 2005 09:54 PM
philly91crx
Jan 13, 2005 07:40 PM
Full Race A6
Jun 22, 2004 07:18 PM
