tire burning
how to perform a correct tire burning? fwd w/ slicks
should it be wet burning?
i dont have a line lock so i will be using the e-brake.
u can post ur step by step procedure.. thanks!
I'm no expert, but just roll into the water, spin the tires once to get them all wet, roll forward a few feet, pull up the e-brake, put car in 2nd or 3rd gear depending on your HP, give it some gas and let the clutch out. Spin the tires until there is a good amount of smoke, maybe 4 or 5 seconds, then release the e-brake and lift off the gas. You'll figure it out. Go practise in some "empty" parking lot.
Watch some videos on Utube...
whatevery u do dont spin yout tires to get them wet....just roll thu the water slow...
brokenojoke
22
Nov 29, 2006 05:50 PM
