has power, won't turn over
Hey guys this is an ultra noob question but please bear with me.
Car has power, fuel pump primes, main relay clicks, and when I turn the key the fuel pump primes agian, and the main relay clicks again. It doesn't even begin to turn over.
I was trying to relocated my battery (it is now back to all stock)
- I know the battery is good
- 1AWG wire from the battery to the starter
- 8AWG from the fuse box to the starter
I put everything back to stock, cleaned up all grounds and connections and still have the
same result.
I have swapped fuses for alternator and starter, they look fine
I am probably missing some thing super simple, any advice would be great!
same result.
the ignition is farily easy, like dude said check battery for voltage and jumpstart it, also double check to power and ground connections on the starter,one might be loose or not on like u thought. also check over and tighten down the two cables in the fuse box.
EF'GSRrr91
Jan 22, 2015 05:29 PM
