Lost as what to do with motor
Old Apr 11, 2010 | 08:34 PM
northcb7's Avatar
Default Lost as what to do with motor
I bought a obd1 gsr motor to rebuild it and put it in my 00 sir (usdm si) And the goal is to achieve 11-12.0 compression. I don't want to break the bank, work is slow spending's tight. Does anybody know of some decent setups that will provide me with what I'm striving for?
Old Apr 11, 2010 | 08:48 PM
cleansi's Avatar
Default Re: Lost as what to do with motor
what is your power goals n/a i take it
Old Apr 11, 2010 | 09:12 PM
northcb7's Avatar
Yes sir I want to refrain from chopping the car all up with a turbo setup. Like I said, moneys tight.
Old Apr 11, 2010 | 11:01 PM
Ruben19's Avatar
u can get some p30 pistons with ctr or itr cams.
or try some blox cams
Old Apr 12, 2010 | 08:00 AM
northcb7's Avatar
If I do put those cams and pistons, how important is it to upgrade valve train and fueling?
Old Apr 12, 2010 | 08:02 AM
ChokolAwt's Avatar
fueling isn't so key if you're not making high hp...
as for the valvetrain. if you upgrade your cams they're gonna make power past the stock redline. either dont go past it or upgrade your valvetrain to reap the full benefits of a cam.
Old Apr 12, 2010 | 08:12 AM
northcb7's Avatar
Okay. If I wanted to do valves, springs, and retainers, whose the best bang for your buck manufacturer?
1993gsrcivic
18
Mar 3, 2008 11:40 PM
1995Civiccx
12
Jun 10, 2007 06:41 PM
93EG6SI
Nov 20, 2005 09:52 PM
grifter413
Sep 25, 2005 10:52 AM
jam05pr
Jun 6, 2005 09:31 AM
