1988 Honda CRX; safe tire and wheel size
Old Apr 11, 2010 | 06:31 PM
BarcodeCRXSI's Avatar
Default 1988 Honda CRX; safe tire and wheel size
I drive a 1988 Honda CRX Si and have these wheels that I'm getting tires for.
The wheels are 17 inches diameter and 7 inches wide. I know that 205 40 R17 will fit the wheels, but I'm concerned about the tire width. Would they perhaps be too wide to where they rub the suspension?
I'm sure I won't have to worry about the tires rubbing the wheel wells since my ride height is the same as stock.
Old Apr 12, 2010 | 04:40 AM
Default Re: 1988 Honda CRX; safe tire and wheel size
I'd hate to have to bump this thread, especially since I am a noobie poster.
I got a great quote on tires and I'm going to be calling the guy today about the tires, but I want to make sure that the wheel and tire width don't become a problem.
Old Apr 12, 2010 | 06:12 AM
Jenkinsal2's Avatar
should be ok but your car is going to look like a tonka toy. Those wheels are way to large for a crx. Have you test fit them yet to see how it will look?
Old Apr 12, 2010 | 06:13 AM
Aftermath_Hatch's Avatar
You should be fine with that size.
Old Apr 12, 2010 | 07:23 AM
acmoc's Avatar
Agreed, largest wheel for a crx is a 16, and only some 16's look good.
Plus the weight will decrease performasnce
Old Apr 12, 2010 | 10:35 AM
Yeah but the weight of these wheels versus the performance is very miniscule in comparison to some of the much heavier custom wheels out there.
I test fitted them and that's why I raised the question about the suspension because in the back it looks really close. I still would have to get an alignment and I Am sure that the caster and camber kit will help out a little bit.
I know that the ones in front have a good chance of rubbing the wheel well but I Am sure I can modify the wells so they don't rub as much, however I may not solve that problem with the transmission on my b16a2 motor under the hood.
Old Apr 12, 2010 | 12:05 PM
once upon a time I had some 18" racing harts on a crx and it worked but looked like a donk. 17" will be fine.
kjames05
Sep 22, 2014 08:22 PM
cecknight
Jan 13, 2008 07:21 AM
88JeepCherokee
Apr 10, 2003 11:14 AM
turbohappy
Jan 14, 2003 10:57 AM
boonacka
16
Nov 14, 2002 08:40 AM
