HELP: D16Y8 Engine
Old Apr 11, 2010 | 06:28 PM
HellYeah's Avatar
Post HELP: D16Y8 Engine
I need help with a problem i'm facing..
I know i have a vacuum leak but i've no idea where from.. I'll be completely stopped with the clutch in and brakes on, and it'll rev for no apparent reason? And i'll go to just regularly take off and it will want to stop? It's hard to explain but if you get what i'm talking about please help me out.
Old Apr 11, 2010 | 06:34 PM
HellYeah's Avatar
Default Re: HELP: D16Y8 Engine
Old Apr 12, 2010 | 10:14 AM
HellYeah's Avatar
Anyone?
Old Apr 12, 2010 | 11:37 AM
sii.'s Avatar
just get some brake cleeaner and start spraying
Old Apr 12, 2010 | 11:51 AM
bazoOKA_ TOoth's Avatar
Try checking out your IACV. Idle Air Control Valve. My gf's car had the same issue, I took it off and gave it a good cleaning and the erratic idle stopped. It also affected acceleration, so Im guessing thats it.
Old Apr 13, 2010 | 03:09 PM
HellYeah's Avatar
^^ thanks bazooka, i took off the whole manifold / intake and gave it a good clean with brake cleaner and it seems to be pretty good,
But NOW.. my brakes are squishy and it idles low with the brakes on sometimes? wonder what that's about..
Old Apr 13, 2010 | 03:29 PM
ek_jap's Avatar
a vacuum leak at the booster maybe
Old Apr 13, 2010 | 04:33 PM
shelbz0131's Avatar
go b series and replace it all
Old Apr 16, 2010 | 02:10 PM
Check all hoses connected from your booster to your manifold. like ek_jap said, might be a vacuum leak. When you removed your manifold the first you might accidentally ripped a hole in one of those hoses. They can get pretty dried out at times. Hit us up with update?
Old Apr 27, 2010 | 06:39 PM
HellYeah's Avatar
I just quit ****in' with it - i let homeboy take my car and rebuild my engine and **** and fix everything thats wrong with it
Freshdot
Jun 18, 2010 06:34 PM
4g4dcruisin
Jan 6, 2010 07:33 AM
supertuner91ef
Dec 20, 2007 05:40 PM
category5 SI
May 30, 2007 04:06 PM
beho
May 12, 2006 02:59 AM
