Are my tie rods out?
okay i was racin one day and all of a sudden my car started shakin real bad and made a sound as if my lug nuts on my rims were loose so i took it to my friends house and checked all the tires they were all on tight so i went ahead and took off my front tires to check it and i noticed my cvjoint was broke well i fixed it thinking that was the problem but it still does th same thing could this be my tie rodes or is it something else thanx in advance
to check tie rods. jack the car up and grab the wheel at 9 and 3 and check for play. while your at it grab the tire at 12 and 6 and check from play that is lower ball joint.
could be, your the only one with the car so your the only one who can check. jack up the car, and shake the wheel, see if it has any play reletive to the knuckle. if it does, have a friend shake the wheel while you look under it and look for what part is moving.
Rickdogg
Dec 22, 2009 10:16 PM
vtec25
Mar 4, 2008 10:58 PM
theemaddhatterr
Dec 29, 2005 02:54 PM
