new alternator...squealing belt
Old Apr 10, 2010 | 04:45 PM
projekt90ef's Avatar
Default new alternator...squealing belt
hey i changed my alternator today. everything went really smooth until i started the car. everything works fine and it starts up good, but the belt is squealing until i rev it, then it goes away. then i would turn the headlights on, the squealing starts again till i rev it. then the heater fan, squeal rev, etc...when i put it in gear and let out the clutch same thing. the belt is in good condition and about the same tightness as with the previous alternator that didnt squeal
the question i have is...
is it the pulley? would it ruin the alt. if i spray wit some wd-40?
or should i try to get the belt even tighter then what it is now?
thanks for reading...hit me up
Old Apr 10, 2010 | 04:50 PM
BiG ChOr!Zo's Avatar
Default Re: new alternator...squealing belt
try some of this available from any vatozone...!!!
Old Apr 10, 2010 | 04:54 PM
EFRue57's Avatar
sounds to me like you didn't tighten it enough. If it wasn't squealing before, but is now, I would try tightening it more first. It doesn't cost anything and only takes like 10 minutes of your time if that.
Old Apr 10, 2010 | 04:58 PM
will do...then ill hit up vatozone for that dressing if it dont help. hahaha thanx
Old Apr 10, 2010 | 05:00 PM
blazzer's Avatar
ya u need to tighten that bad boy happend on my bro's crx. go find like a pry bar and push it till there is some nice tensionon it and then tighten the bolt should fix it :D
Old Apr 11, 2010 | 01:21 AM
skipbudlong's Avatar
Or maybe you didnt put it on the right grooves. Mines did that and i put the belt back more and stopped the squeling.
Old Apr 11, 2010 | 10:35 AM
no its fixed...took me 5 minutes to loosen the bolt and tighten it while i pushed on the alt...me an my dumb *** hahaha
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
Import_Dumbass
10
May 21, 2006 03:59 PM
failed
Sep 4, 2005 05:59 AM
JMod
16
Jun 23, 2005 11:49 AM
keithv
Aug 7, 2002 04:40 AM
