mini-swap vtec oil pressure helpp
so i'm doing a mini-me swap on my 92 hatch with a 96 d16y7 motor in it. And i put on the new y8 head and everything else, but the only thing i dont no is which plug on the ecu the oil pressure sender goes to... im stuck, any help?? i didnt no if there was a post already on this so sorry if there is. And my car setup is obd1
Google [your specific] ECU wire pinouts. Actually it's probably in the FAQ, the first place you should look whenever you have a question.
oil pressure sending unit I believe goes to the dash to the light that comes on when the oil pressure is low, I don't think it goes to the ECU, but for reference
