PA FS: 1996 GSR DB8 SEDAN $4500 FIRM
Up for sale, my 1996 Acura Integra GSR sedan. 172K on the body, 75K on rebuilt GSR tranny, 90K miles on motor built by Hybrid Dynamics. i've owned this car since it had 64K miles on it. 1000's invested in new and aftermarket parts. I've had the car for almost 7 years and it has been meticulously taken care of and maintained. Car is by no means a race car, so if you're looking for one this isn't it. It is quick, and very fun drive and handles great. Car still pulls hard and gets on average 31 mpgs. I just ran a compression test on the motor, 205-205-205-210 were the numbers, still very healthy motor. This car was my daily driver, and my college driver. Most of the miles are highway miles back and forth from Morgantown Wv.
NO JOY RIDES! If you're interested in the car, better bring some cash(more than a couple hundred dollars) to show you're serious. If you don't, no problem we can still go for a test drive. However, i'll be doing the driving. I've put way too much time and money into this car to let someone come beat it up who has no intentions of buying it.
Car is inspected until August 2010, passed no problem. The car will also come with a some of extra stuff I'll have no need for anymore.
$4500 no negotiating, price is frim.
also, i will not finance this, i will not accept payments unless it is one payment of 4500, i will not trade
i dont need to sell this car, so dont low ball me. i have too many toys, and this car sits more often than it gets driven. i try to drive it once a week just to make sure everything still works and there is no issues popping up from it sittin in my driveway.
here's a list o stuff:
1996 acura integra gsr DB8
vin: JH4DB8591TS000923
cypress green pearl
PA inspected until 8/10
tan cloth interior(leather looked like crap, switched it out)
172K miles on the chassis
90K on the motor that was built by hybrid dynamics
75K or so on the rebuilt gsr tranny
oil changed every 4500 with mobil 1 5w30 synthetic
tranny fluid changed every year with pennzoil synchromesh
motor mods:
ES motor mount inserts
aem short ram intake
jdm iITR 4-1 exhaust manifold with skid plate
full 2.5 " exhaust, carsound cat, dynomax ultraflow muffler all painted flat black
bored stock TB to 64mm
b&m FPR with gauge
CTR cams and valvesrpings
exedy stage 1 clutch (35K miles)
lightened and balanced type r flywheel
dyno tuned by hybrid dynamics with vafc2 (164ishwhp) i forget the exact numbers
powersteering rack loop kit to elminate the power steering(this car really doenst need it)
chassis:
lowered on kyb gr2s and ITR coil springs
most of the energy suspension chassis pieces
rear strut bar
omni power adjustable upper control arms
interior/exterior:
15 rota group n wheels painted light gold, dunlop tires 195 55 15 (about 5K miles on them)
ITR urethane lip(paint matched)
JDM integra emblem(rsx font)
OEM JDM yellow fogs
autometer oil pressure gauge
autometer a/f gauge(not currently hooked up)
green neon accents under dash and rear seat
s2000 antenna
4300K hid PnP kit
ICE/security:
factory acura cd headunit with cassette
kenwood components front, kenwood 6x9's rear
presige keyless entry alarm
hard wired cobra radar detector
most recent new parts
about 20K miles ago i think, oem water pump and timing belt, tensioner etc..
new 3 year warranty battery
new lower ball joints(30K)
new inner and outer moog tie rod ends(30K)
4 new calipers, new wagner pads front and rear, new brand "x" drilled and slotted rotors(5K)
new radiator and cap and new hoses(<500miles)
new oem t-stat
car was just repainted august 07 (oem Cypress green pearl)
new clutch master and slave cylinder
new throwout bearing
new rear main seal
New cap, rotor, NGK wires, NGK laser iridium plugs, new ICM, new Ignition coil
new rear trailing arm bushings
replaced sunroof motor
the bad:
ABS is having solenoid a solenoid issue. i have a used workin abs module to go with the car. i dont have the space or the time to replace it myself, and most people remove this item from the car anway.
after being in PA for 6 years, one rust bubble finally showed up. i sanded the rust down, put chassis saver over it and touch up painted the spot, the bubble spot is still there but no additional rust has shown up for the better part of a year now. i believe it is stopped.
the ITR lip is starting to get some chips in the paint
driver side headlight just started developing some condensation in it after the 2 feet of snow we had
the cruise control doesnt work, i've tested every part except the brake light switch, all tested fine so i'm going to assume its that part of the switch that is bad. again, i dont have the time or space to work on the car anymore, and this is another part hat most people remove anyways.
some extra stuff to be inlcuded
couple pics
cypress green pearl
motor mods:
b&m FPR with gauge
chassis:
rear strut bar
interior/exterior:
OEM JDM yellow fogs
s2000 antenna
4300K hid PnP kit
ICE/security:
new oem t-stat
new rear main seal
the bad:
couple pics
ya, i just dont drive the car more than like 10 or 15 miles a week, someone else need to appreciate it and drive it and appreciate all the time i've spent makin the car what it is.
FYI if someone local buys it and i see a huge wing or bodykit on this car, i will run you right
off the road haha
tranny is rebuilt, motor is not original, and its rebuilt. when i bought the car the engine shot a rod through the front of the block after i had the car for about 3K miles. they didnt cover it under my warranty because the throttle body was dubbed the reason the engine blew and magically it was the only thing not covered under my warranty, so i got rid of the warranty and bought a used motor out of a 98 gsr. then that motor was the one that was built by hybrid dynamics. it was a stock rebuild on the bottom end, and the CTR cams and springs up top. im not sure if i still have the slip that listed everything they redid on it, i know it was a full tear down and rebuild, my car was gone for a while haha.
thats another thing i forgot to mention, i have most of the recent receipts for parts and work done etc..., i lost a lot of them tho when my garage flooded a couple years ago.
cottman transmissions rebuilt the tranny. the engine bay isnt as impressive as it was before, but i'll get some pics of it. brake fluid spilled on the valve cover so some of the paint is chipped off.
heres the rust bubble. its been like this for almost a year now, hasnt gotten any bigger, just kinda stays there.
