Interchangeable parts off prelude??
can we make a list of items that are interchangable from other cars? ie. Legend,Wagon, the van *cant think of name*, prelude..
like i know several nissans can use the cobra mass air sensor. and its huge... just wondering if we can put it together
cant we use like a CL sway bar or somethign. cause alot of times other models might be cheaper to order and if they fit .. why not?
with the proper tools and imagination almost everything is interchangeable, the starter is not though
prelude knuckles will fit with a tie rod and lower ball joint swap, the engine/tranny(duh), seats, suspension (with a little modifying for brake line placement) etc., etc.
other things like the New generation Civic SI brakes are interchangeable
**** my suspension is a combination of four different setups...........
Other things are clutch, flywheel, fuel rail, fuel pressure regulator, alternator.... All of these can be bought and interchanged between the two cars.
